    121
    fixing a broken receiver antenna- possible?
    I currently have two traxxas TQI receivers with broken antennas, and on one of them i have the other end of the antenna. since these receivers are somewhat costly, is there a way to fix them? I would like to know if the other end can be soldered back on and if there is a way to use something else, such as wire from a 27mhz receiver or something similar. Thanks.
    Alma, MI
    12,279
    Yes, it is possible to fix them.
    How much of the original antenna is still left attached to the circuit board?
    The antenna for the TQi is not a single wire, by the way. It is a coaxial... there are multiple layers of wire and plastic in that thin line!
    121
    I have two like this, they both have about 4-6 inches left on them.
    How would you fix this?
    Alma, MI
    12,279
    121
    I don't quite understand what to expose on the wire, could you or someone else show me a diagram of the wire and what to cut please?
    Alma, MI
    12,279
    There is an outer layer, a wire mesh layer, a plastic layer, and a center wire. The center wire is what does all the receiving for the receiver.
    Mar 2013
    New Hampshire
    563
    I need to fix mine but on the receiver side there's only about an inch of wire. Its not completely broken, just the outer layer of wires, does this matter?
    And we thought toy grade RC's where cool...
