Results 1 to 13 of 13
    Mar 2014
    31
    Lipo gearing rustler vxl
    Hi I was wondering which spur gear to use for 2s lipo on a rustler vxl. I can't change the pinion because it is stuck on the shaft
    Middle, Georgia
    1,214
    What are you wanting to with your rustler? Bash or speed runs
    You could always get a bit from almost any store like Lowes. The bit is for stripped screws.
    Sent from my SCH-I535
    Dec 2013
    WI
    374
    I'd try to get the pinion off first. Is the set screw stripped out or something?
    Mojave Desert
    1,580
    Quote Originally Posted by Themader346 View Post
    if you're using the stock allen wrench that came with the rustler then yea the pinion wont come off with those once it's semi-stripped. You'll need to invest in a good set of hex drivers 1.5mm, 2.0mm and 2.5mm for your truck...as of now to get the pinion off, head to your local hobby shop and they'll whip out the right tools to get that pinion off.
    Mar 2014
    31
    Quote Originally Posted by brandon555 View Post
    I tried to drill out the screw but the gear is still stuck of the shaft
    South of St Louis
    5,986
    What gearing is on there now? There may not be many options depending on how small the pinion is.
    Mar 2014
    31
    What ever the stock pinion is that comes on current rustler vxl and I have stock spur 76t spur and 90t spur
    Mojave Desert
    1,580
    once again...before over-doing things by drilling...what tools are you using to get it off? if not using hex drivers then you should try those FIRST. Your local hobby shop will help you get that stuck pinion off easily.
    Mar 2014
    31
    Quote Originally Posted by G-Rustler View Post
    I tried the hex driver from the duratrax tool kit and all it did was strip it. I tried using a star head driver. But that just dripped it more. So then I tried drilling and the screw is completely gone but the gear is still stuck.
    589
    You either need to drill deeper, or wider. there could be a bit of screw left in there. OR you could cut the gear to pieces with a dremel ect. OR pelieve it or not there is a puller for them gears. OR could be somebody used way to much locktight ( not likely if ya bought it new )
    589
    Also as always bigger pinion = more speed, smaller spur = more speed.
    Try it like it is first, might be fine for what your doing.
    Mojave Desert
    1,580
    Quote Originally Posted by knall View Post
    yes the hobby shop will have this puller device that will yank it off. I find it strange that the grub screw is off but the gear is still stuck
    Mar 2014
    31
    I don't want to drill anymore because I know I'm at the shaft. I went real easy at the end and when I tap the shaft it sparks and I'm afraid of damaging the shaft
