Results 1 to 31 of 31
    Feb 2014
    56
    I want to go mamba micro
    Hello I want to put a mamba micro pro with the 0808 4100 KV motor in my Teton. What do I need to do? Will the esc fit without mods? And what mods to I need to make for the motor to fit? Also how can I solder a trx connector to mamba micro pro? Any help is wanted thanks.
    Feb 2010
    Va
    476
    They esc does not fit right in. The motor plate needs to be modified. Some people have been opening up the banana shaped part. But I just drill out the single hole. I can put up pics of you want. And for the connector. YouTube. Squirrel has a good video on it
    Twin Brushless Latrax Teton, .21TM Jato
    Feb 2014
    56
    Coulda post pics of mods needed? Also does the banana shaped one come with the motor? What do I need to do to the esc?
    Feb 2010
    Va
    476
    You don't need to do anything with the esc besides the connector and securing it down where the stock one was. It's just that black plastic guard that covers the receiver and goes around the stock esc hast to be cut on the esc side to fit in the wider mamba micro pro. I'll get some pics up
    Feb 2010
    Va
    476
    Here's the box and where I cut it
    [IMG][/IMG]
    And here's where I drilled. It's a size 5/32 bit.
    [IMG][/IMG]
    Feb 2014
    56
    And that's all?
    Feb 2014
    56
    I would actually rather go with the castle 0808 and the vxl 3m. So all I have to do is widen that hole with a 5/32 bit? How much do I drill
    Jan 2014
    186
    Its so easy to do, I did mine with metal file
    Feb 2014
    56
    Ok sounds easy one more question do I make the whole circle bigger or just do one side?
    Feb 2010
    Va
    476
    I went right down the hole so it opened it up equally all way around.
    Feb 2014
    56
    And does it matter about the motor/esc plugs do they have to have a certain combo I notice the vxl 3m connectors are color coded but the 0808s are all black
    Feb 2014
    56
    After I am done will it beater than my mini e revo vxl?
    Jan 2014
    Long Island, NY
    256
    Quote Originally Posted by ThatdudewithaMERV View Post
    Nope but it will be quick, I used the Castle Sidewinder Micro on the rally and the ESC fits right in with minor dremel work to mount the motor.
    ERBE, LaTrax Rally, E Jato, and Spartan
    Feb 2014
    56
    Oh good cause I want my MERV to be WAY faster
    Feb 2010
    Va
    476
    The pro doesn't fit right in though. It's in a case, also has better parts. In my opinion it's worth the extra money
    Feb 2010
    Va
    476
    You need to look into the vxl 3m to make sure it can run the 4 pole castle motor
    Feb 2014
    56
    Lipo-powerplease set one up like that
    Mojave Desert
    1,605
    Quote Originally Posted by duramaxin View Post
    thats my hesitation from purchasing that combo. i wanted to get the vxl 3m with the castle motor but seeing that the motor was a 4-pole made me stray away from purchasing it.
    Feb 2010
    Va
    476
    Guess it works then!!
    Feb 2014
    56
    ctually he did it with the mini. Otor that came before the four pole. Is the velioneon motor a 2 pole? I will look this up to see if it works and its worth a try I guess if it doesn't work you have a brushless esc and motor lying around
    Feb 2010
    Va
    476
    Yea it's a two pole. You can always just put the velioneon motor in your Teton
    Feb 2014
    56
    I will go with mamba micro pro but I want it waterproof... How can I waterproof an esc?
    Feb 2010
    Va
    476
    Take the plastic case off then you put liquid tape all over the circuit board. Then you would use a clear silicone over the lights so you can still see them. There are some videos on the tube on how to do it
    Feb 2014
    56
    So I just put liquid electric tape all over except for the led light and put clear silicone over that?
    Jan 2014
    186
    I have the 4100kv and I just snapped a drive shaft... Running fwd now
    Feb 2014
    56
    I will get metal driveshafts when I go brushless cause I won't get it for a month or so (want to wait) so I have bookmarks of products for brushless and waterproofing the brushless system. Is this all?
    1.Esc/motor
    2.Traxxas connector
    3.soldering iron
    4.Solder wire
    5.shrink tube
    6.liquid electric tape
    7.Clear waterproof silicone
    8.traxxas metal driveshafts
    Feb 2010
    Va
    476
    Yea, you might want to order spare spur gear, just to have. Also good lipos and a good charger if you don't already have those. Also, your going to want to glue your tires or your rim is just going to spin inside of the tire. I use superglue. Works great.
    Feb 2014
    56
    I have my tires glued with foam! Also I have a 2s and the 6ampez peak
    Jan 2014
    186
    If your ESC and motor came with Bullet connectors installed then u don't need shrink tube. Every traxxas connection doesn't need shrink tube, that's why I like traxxas connector
    Dec 2013
    Cape Coral, FL
    173
    The problems I had with the vxl-3m was with the 6800kv 2 pole motor, if you ran a 3s on this motor, the esc has a rev limiter..and no the vxl won't run the 4 pole castle motors, well it will but half as fast....now I run the mamba micro pro with 3s and am very happy. Now just need better driveshafts...lol
    Feb 2014
    56
    Thanks lipo power, I am going to do mamba micro with 0808 4100kv motor and I will waterproof the esc. Does the brush on electric tape work every time and just to be safe could I put a ton on so I don't see ANY circuit board?
