Results 1 to 23 of 23
    Feb 2014
    14
    Brand New ERBE Problems!
    Hey guys. After maxxing out my 2 month old rustler with the castle 2400kv motor I decided to pick up a new Brushless E-Revo.. I wore the supplied nimhs dead to break in the car a little and dropped in 2x 3s spc lipos and the erbe just fell apart.. Within about 2 minutes both rear and one front axle had snapped. Luckily my hobby shop is only blocks away and I was sold the 5451r's (cvd's) against my request for the summit shafts I read about being the way to go on this forum. 10 minutes later they were all twisted, just barely, but the car sounded beat at speed from the axles wobbling out of true. After getting home the car was torn down for further inspection and found the shaft from the trans to the rear diff was also wobbling and beginning to twist. I am aware of the losi diff mod and want to start less extreme. I was hoping the new erbe was more turn key than my heavily modded street rustler but couldn't even live up to a single lipo drain. Any suggestions on the axles and or center drive shafts? I've spent so much more time than I thought necessary searching all the forums for go to parts...
    Thanks for any info!
    Mar 2014
    you need a castle link. de tune it for 6s
    Feb 2014
    14
    thanks Kelly. I've got the castle link and would love to understand what should be de-tuned. on my 90mph rustler I only reduced the punch.
    Land o' flat.....
    978
    The Erevo does well on 4S, but tends to break more stuff on 6S. If I were you I would see if you could borrow some 2x2S and see if you like running your ERBE on 4S. Then maybe think about buying new lipos. I had a ERBE, and I thought it was plenty fast on 4S.
    Slash MT, 1/10 Summit.
    Feb 2014
    14
    Thanks for your input sumbasher.. as far as power goes I'd only go higher (8s) as the build progresses. I'm actually aiming to part with the rustler to fund a 1717 setup but looking to gain my confidence back in the car all together after melting down with less than 10 mins of drive time...
    Sep 2013
    231
    Quote Originally Posted by illlili View Post
    It all varies with every experience in my opinion. For instance. I have about 20 hours of 6s on my e revo with only one broken half shaft.
    Sent from my SM-N900P using Tapatalk
    Feb 2009
    714
    Unless you are getting more air time than Tony Hawk that amount of parts should not be breaking. Adjusting your slipper settings so it actually works instead of it being locked out would be a good place to start as a slipper clutch that is working properly can save your axles by not transferring such abrupt throttle inputs to your driveline.
    A couple of settings you could change in your Monster is torque limit setting limiting the amount of power available, change the timing to 0 or 5, set the start power to low, punch control to 75 or 80%. if you have questions on how to use the software just click the little blue question mark and it will tell you what each setting does. Takes some time to read the directions but it is worth it in the long run.
    There are lots of ways to de-tune the MMM the best of which is learning throttle control.
    If it didn't break you can do it again.
    Apr 2007
    Valrico, FL
    1,679
    Quote Originally Posted by afterdarkgames View Post
    What he said.....you can't just run a locked up slipper and slam the throttle around on the erbe when running 6s. The stock power system on a erbe running on 6s puts out as much as 5 horsepower...instantly. A properly set slipper clutch and good throttle control will save you all kinds of repair bills. You'll still break the stock diffs and driveshafts, but you should be able to have a lot of fun before that happens if everything is set up properly and you realize that the throttle is proportional, not just on or off.
    -ERBE
    -Slash 4x4
    Feb 2014
    7
    i think there well built i broke a rear end cause of faulty pinion bearing big deal ive dumped tons of upgrades into this truck that it didnt need but i bash it hard its a monster
    mamba monster 2 waterproof WoW awesome
    tvr chassis brace rear
    rc soultions full roll cage
    tvr steel axles
    titanium skids
    rpm arms all the way around
    aluminum steering blocks
    aluminum transmission
    trenchers x on f 11s gorrilla taped
    single 370 o torque servo hitec
    you wanna race hehehe:0
    Feb 2014
    14
    Thanks for all the advice guys. I will try loosening the slipper and make the recommended esc adjustments. I guess I was just used to punching it with the rustler which is weighted down up front. I've ordered the long summit shafts to replace the danged ones. Would there be a more durable center drive shaft anybody recommends? Or just another stock unit? Thanks!
    Mar 2013
    369
    i left all mine stock.you need a breaking point somewhere and they are pretty cheap to replace if needed
    Feb 2014
    7
    stay stock there cheap cause the metal ones are going to cost way more and break more learn from others not from ur wallet
    Mar 2014
    8
    I do not mean to be rude, but it's in your driving style. The car is a ****** monster on 6s. What you can do to save the car:
    • Middle diff with thick oil (have no number, i'm still experimenting with this after removing my 2speed gearbox)
    • Do NOT EVER land with throttle on, preferably as little wheel rotation as possible
    • If you have your tyres loose from the rims, turn them inside out and duct tape them before you put them back, this will make them balloon less.
    • Make a few aligned holes in the middle of your tires. Preferably a soldering iron or a hole puncher. But it also works if you have something thin and very pointy, the hole doesn't need to be big at all, because there are extreme G forces in the tyres to get water out
    Well these are a few things to ease up the damages to the car, just think about where you can reduce rotating force.
    Austin, MN
    10
    I just picked up an ERBE from Tower...I LOVE it so far, I did instantly upgrade to Trenchers on 1/2 inch offset wheels, and picked up some 2S lipos for it, broke the truck in on the stock nimh batteries, but then put in the lipos and ran it...not as fast as my old 2WD Stampede Vlx, but, gets through all the snow here in Minnesota much better (no brainer) I have had a 3.3 Revo and a 2.5 TMaxx (upgraded to 3.3).
    I LOVE THIS TRUCK!
    Smooth, powerful, and plenty of speed with 2S, I have 3S for it, but, will reserve those for show off time around my buddies.
    Nothing broken yet, but, I will be buying Summit axles to have on hand (no local hobby shop) and can say this is the most competent truck I have ever run...it's better, in my opinion, than the nitro trucks by far, and is huge and fairly heavy...flies like an eagle and is very controlled in the air.
    Love it!
    Feb 2014
    14
    I'm willing to bet my over-tightening of the slipper was what caused all the issues. The first run with lipo's (6s) The car accelerated as though it was on ice, Tons of sound but little movement. Tightened the slipper about 1/2 turn and the car then became punchy, responsive and could even do a standing back flip. I admit that after seeing an erbe on youtube doing backflips one after another I simply assumed the car was stronger.
    Quote Originally Posted by LilleCarl View Post
    Apr 2007
    Valrico, FL
    1,679
    Yeah, If you can do standing backflips you definitely need to back off on the slipper a bit. The diffs and drive shafts won't take that kind of beating for long, as you found out unfortunately. On 6s the slipper adjustment range is very small, less than a half turn of the nut to go from too loose to too tight.
    -ERBE
    -Slash 4x4
    Mar 2014
    8
    It is unbelievably strong, it's just a very overdimensioned motor system on it, doing standing backflips is just begging to break the transmission.
    The motor system has about 3.6hp and incredible torque, so remember that.
    Feb 2014
    14
    Hey Guys, I was hoping to create a new build thread after finally receiving all the needed replacement parts and several upgrades, however after running the car for its 3rd time (less than 10 mins on car) there is a loud slapping sound coming from what I believe is either a diff or trans. The sound does increase with motor rpm. Suspending the rear wheels and applying throttle the noise is not heard, suspending the front and applying throttle in reverse the noise is heard. Any input? thanks
    Sep 2008
    Turks and Caicos Islands, BWI
    617
    This thing is a monster on 6s... Back off your slipper clutch a little bit, should help with those twisted drive shafts when you punch from a stand still. And while on 6s, be careful, trees and boulders and poles and bench feet pop up out of nowhere lol!
    Ray00
    E–Revo │ E-Revo BE
    ITCHY THROTTLE FINGER!
    Feb 2014
    14
    tttttttttttttttt
    May 2010
    275
    Sounds like your rear diff/trans is shot. If it makes noise with load on the diff then theres probably something wrong in there, take it out and investigate. The damage was probably already done by the first run or two and now finally surfaced after another run.
    2x 2wd Slash|Slash 4x4 PE|MM E-Revo|Grave Digger
    Jan 2014
    102
    True. It all depend on how you punch your trigger it you may have set it using your TQi+iPod. I live expo setting on TQi, it ease the torque, I have twisted 2 stock shafts before understand the setting, I.e. Slipper clutch, TQi with iPod, Punch control, expo, etc.
    Anyway, this what actually happened to me. I'm mostly running 4s on normal bashing (with all set as above). I do enjoy the speed and the power and little love of protection to the ERBE itself (easy throttle, TQi etc). And when in racing at my local track, I never ever see that I need 6s, it's not that I don't like it. I don't see I need it, the moment your ERBE launch, use t the end of the track already : ) and without the proper expo and ease on your throttle, your ERBE will wheelie a lot and I don't see it's practical for racing, yes for bashing and fun. But not for racing.
    Frankly, speed is temptation, especially with not a real car that you sit in it. You are not afraid to go taster, it's tempted! We'll I do run on 6s once in a while but always be gentle on throttle. Or you'll break almost everything. So I don't see the point of braking everything and wait for part replacement and the ERBE lay down waiting for help : )
    Unless you're saying you're a speed demon, than you don't have other choice to upgrade your ERBE to almost bullet-proof but yes, there are still possibility of parts to be broken.
    Well, enjoy the bash, the race at 4s. If you don't mind to drive a little slower. P.s. Top speed of 4s is enough to make me panic sometime
    My 2cents.
    -bashdemon-
