    Sep 2013
    235
    More cc bec questions.
    So i got my bec soldered on and I'm going to use the servo extension for the esc wire. Where can I plug the bec into on the tqi traxxas receiver? I've read any open port but just want to verify. Also I was wondering if any of you use the bec for more than 5 amps with the stock plug (on castle website they say to change the connectors if you want to go higher than 5amps) just want to see how you all have done it and had it working properly. Thanks!
    Sent from my SM-N900P using Tapatalk
    Sep 2013
    235
    Any thoughts?
    Feb 2013
    Belgium, Antwerpen
    60
    You can plug it any open port in the reciever. I've never gone over 5 amps not even with a full set of LEDs and a power hungry savox servo, castle recommends changing the plugs but i think it works fine if you keep the stock ones.
    I hope this is helpfull.
