Page 1 of 2 12 LastLast
Results 1 to 40 of 42
    Feb 2014
    29
    brushless options for 1/16 digger
    I'm looking at upgrading my son's digger to brushless. Has anyone had experience with the hobbywing 1/16 system? Seems like a good deal for under $50.
    Dec 2013
    1,346
    can you post a link
    Dec 2013
    1,346
    id go with the 5200kv motor
    Feb 2014
    29
    Is the hobbywing stuff pretty decent?
    Dec 2013
    1,346
    Idk but why don't you get castle, usually cheap means bad product iin some case like integy
    Feb 2014
    29
    Which castle?
    Jul 2012
    Yakima, Washington
    1,421
    That castle motor/esc combo is too small for the truck if you want castle you have to go 1/10 scale
    http://www.amazon.com/Castle-Creatio...e+sidewinder+3
    Feb 2014
    4
    Agreed that castle is for 1/18 trucks I'd go with a 1/10 sidewinder3 tough fit especially in a grave digger though
    Dec 2013
    1,346
    is there enough room for the sv3 tho
    Dec 2013
    WI
    379
    A Castle 4600 or 5700 should drop right in or theres the Tenbol mount as well if you opt for that.
    I got my SV3/4600 combo for 99 bucks on eBay.
    The Sidewinder will take a little creativity to make it fit but people usually just mount it on its side where the old ESC was.
    Alma, MI
    12,282
    The HW stuff you linked too is too weak... you want at least a 60 amp ESC and somewhere around 4,000Kv for the 16ths. The stock V380 motor is a very hard motor to beat for affordability and performance. It will, however, require a different motor mount, motor plate, and hardware.
    7077 Gear cover/Hardware
    7090 Motor Plate
    7060 Motor Mount
    The physically smaller motor will help lower center of gravity so you can have better handling with the added speed.
    Feb 2014
    29
    And the vxl 3m esc or would you recommend a different choice? I guess it would be nice to stay waterproof.
    Alma, MI
    12,282
    I would choose something else... it is a weak point in the 16th power system.
    The Sidewinder 3 is waterproof and a common upgrade choice.
    Feb 2014
    29
    Thanks everyone. Lots to think about.
    Jul 2013
    Connecticut
    615
    Funny thing a vxl-3s and a vxl-3m are exactly the same price
    Feb 2014
    29
    Just a thought... does the velineon 3500 from my p4de vxl fit?
    Alma, MI
    12,282
    Yes it will with the 550 mount parts.
    Feb 2014
    29
    And is the sidewinder 3 esc still a good match to the 3500?
    Alma, MI
    12,282
    Yes.
    Keep in mind that with the extra power and the high center of gravity with the V3500 handling will suffer. This is why I suggest the smaller V380 motor... but if you already have the V3500 you might as well put it to use.
    Feb 2014
    29
    Cool. Don't know if I'll install it right away but I did just order the sct 3800 combo for my stampede so I'll have the v3500 as "extra". My plan is to convert the mini digger to 4wd first then switch to the v3500 and the sidewinder 3 esc.
    Covina, So Cal
    638
    I upgraded my son's GD to brushless using the Traxxas Velineon 380 system. It's also upgraded to 4WD. He's been running it for two years now with only 2 servo, and 1 axle failure, and he beats on it pretty hard! I'd have to say stick with the Traxxas setup, but if you go different, Castle can't be beat for power & reliability.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    AB
    I'll try anything once, maybe twice!
    Feb 2014
    29
    Very nice aburg2. Do you have any videos of it?
    Covina, So Cal
    638
    Quote Originally Posted by headstrong4 View Post
    Here's one from about 8 months ago. He's 6 now, and can drive it like he stole it!!! The GD is geared down to a 16T pinion/55T spur, also I installed a 2218X RX in it. He has a TQi Tx with docking base, so I can tune it down farther. In the vid, it's running at 60%, now he's up to 100%. It's also running a center diff with 100K oil in it, so no wheelies, and great traction.
    [IMG][/IMG]
    AB
    You may have to click in the image to run the video....
    Also, it's running 2 1200mah NiMh batteries in parallel for a run time between 40 & 50 minutes.
    Jan 2005
    Nuclear Power Plant drainage ditch
    2,714
    So if it's down to the VXL3M and the Castle SV3 3800k combo, which would be better for handling and longevity-only running 2S batteries.
    All those who believe psychokinesis raise my hand
    Covina, So Cal
    638
    Quote Originally Posted by Buzzforbrains View Post
    I'll have to be honest with you, even though its NOT recommended, I've run 3 of my 1:16 scale road cars on 2 2S LiPo's in series just for speed runs. I took them out of LVD/LiPo mode and fooled them into thinking that I was running 2 MiMh in series. The voltage fully charged is actually lower for the LiPo's in series than the NiMh's! But, you get more punch! They went into thermal protection after around 10 minutes, but I haven't smoked any! They're still running, which proves to me, they're a worthwhile investment. There's also a guy on one thread who has mounted a VXL3S on a 1:16 chassis, using the 380 motor. I still say, either way, Castle, or Velineon, you can't go wrong. And again, what I did is NOT RECOMMENDED!!! But it was fun!!!
    AB
    Jan 2005
    2,714
    Quote Originally Posted by aburg2 View Post
    AB
    Would you go with the smaller Velineon or the 1/10th scale Velineon?
    Covina, So Cal
    638
    I'm running the smaller ones now, but plan on testing the bigger one. Also, the bigger one has a lower voltage limit than the smaller one...I thought I would be able to run 2 LiPo's in series safely, but they are limited to 3S max...
    AB
    Also, my boy has been running his GD for two years, without an ESC issue...I'm just sayin'...
    Feb 2014
    29
    Well, last night my son ran it directly into a tree and snapped the chassis. Now I'm thinking the rebuild may include the velineon 3500. I'll probably change to 4wd at the same time. Any other upgrades I MUST do while it's apart?
    Jan 2005
    2,714
    AB
    How is the braking power with your truck?
    Saskatoon, SK, CAN
    222
    I'm happy with the 1/16 velineon in my sons digger, been going strong for over a year now, gearing is 18/55, I got the toyz chassis braces and they have been good, also lots of other stuff, lol, heres a few pics
    and a few vids
    https://www.youtube.com/watch?v=jYbXjw66igQ
    https://www.youtube.com/watch?v=-0_LxY1l8U0
  33. #33
    Jun 2013
    Ontario, Canada
    259
    Instead of using the 3500, I would buy a Velineon380 and use it with the vxl-3s that you already have. Its an excellent and inexpensive motor (prob pound for pound the best motor Traxxas makes) and you will benefit from the lower center of gravity.
    I think it can be had for around $40 on ebay
  34. #34
    Feb 2014
    29
    Will the center of gravity be much different with the 3500 over the 12t titan?
  35. #35
    Feb 2014
    29
    Suggestions on what pinion I should put on with the v3500?
  36. #36
    Feb 2014
    29
    I switched everything over to the new chassis and switched to the vxl 3s system. After assembling, it seems the servo isn't working. It makes a noise whenever power is on but doesn't move with the steering control. I tried switching channels and relinking but does the same thing.
  37. #37
    Alma, MI
    12,282
    Center of gravity will be different due to the heavier motor. How different I do not know.
    Start with your stock pinion and adjust according to temps.
    Is the servo plugged in the correct way?
    Have you tried plugging the ESC into channel 3 and the servo in channel 2 to see if the trigger will operate the servo?
    I would also try to move the servo manually. It may be stuck.
    It is not uncommon for the 16ths servo to quit unexpectedly.
  38. #38
    Feb 2014
    29
    Thanks j.n. I tried the channel switch and still the same.
    I just figured out I hadput it together 180 degrees out and I think that was messing with it. I flipped it in now it seems to be good
  39. #39
    Covina, So Cal
    638
    No problem whatsoever, actually, it almost wants to nose over upside down! It actually will lift the rear wheels off the ground!
    AB
  40. #40
    Feb 2014
    29
    I got the 4x4 kit installed with the V3500 and this little thing is a blast. We haven't run it on lipo yet but have had some serious fun on parallel nimh.
