Results 1 to 9 of 9
    Sep 2013
    230
    A Few Questions! First Major disassembly
    Hey everyone, i just took apart my e revo to clean it up before posting it up as a roller (bought roller from NFS that was dyed black), so i found that a few of my rpm carrier bearings were kind of frozen up. is there anything i can do to clean them up, or am i just best off buying new bearings. Thanks in advance
    Jan 2009
    Edmonton, Alberta
    1,220
    Personally, I would be replacing them. If it is the 8x16mm carrier bearings that you are referring to, then just go with avid bearings or really upgrade to Acer ceramics.
    1717/XL2 EREVO
    Sep 2013
    230
    Yeah. It is them. The bigger ones and the smaller ones both froze up. But the front bearings are just fine..
    Sent from my SM-N900P using Tapatalk
    Jan 2009
    Edmonton, Alberta
    1,220
    The back ones get hit with a lot more dirt and need more service than fronts
    1717/XL2 EREVO
    Sep 2013
    230
    Quote Originally Posted by UberBricky42 View Post
    i suppose that makes sense? any way to prevent that from happening?
    Jan 2009
    Edmonton, Alberta
    1,220
    Just cleaning after runs, keep the bearings lubed.
    1717/XL2 EREVO
    Sep 2013
    230
    What's the best to lube them with. So take apart the car after every run?
    Jan 2009
    Edmonton, Alberta
    1,220
    I use acer sin lube on mine, and don't take it apart but I'll take my wheels off after a really dirty run.
    1717/XL2 EREVO
    47
    Just pull the dust shield off the bearings and inspect them, clean them out with compressed air and a little wd40 and if they free up and look ok throw a couple dabs of grease in there and work it around by spinning the bearing and pop the dust seal back in. I have had good luck doing that.
