Results 1 to 24 of 24
    Feb 2014
    22
    any input is appreciated
    hi guys, had my first run with the XO-1...rans fantastic, however when the car reach about 100ft it stops....then if i raise the transmitter up it starts to move again.
    the car is brand new and has NOT been unlocked....any thoughts? thanks a bunch!
    Dec 2013
    190
    Have you tried a simple range test? 100 feet is not very far at all. Something is wrong.
    Have a friend stay with the car. Walk 100 feet away and test the steering servo Right, then Left. Have your buddy give you a thumbs up if it's working..
    Repeat test at various distances up to, 1320 feet. It should work at least to 1320 feet (1/4 mile).
    Do you have fresh batteries in the transmitter?
    Jan 2014
    S. Carolina
    14
    I know Traxxas ships some models without the RX antenna mounted. That would be my first check past TX batteries.
    Feb 2014
    22
    at about 100-150ft the cervo right and left struggles and the car stops as if theres no communication between tx and rx, then when i raise up the tx the car starts to move/ tx batts are fresh and the rx has a tiny antena, i dunno if theres a way to set the transmitter to full distance somehow, i dunno if the antena is supposed to be this tiny, i took off the black thing on top and it seems like there's nothing inside that blue pipe thing..
    561
    The problem you have is the exact same problem I had with my wife's Summit. On your blue pipe thingy (antenna) take the black cap off. You should see a wire at the top of the blue tube. If that looks good, Traxxas will give you a new Transmitter & Reciever.
    Dec 2013
    38
    Also check the wires inside the water proof receiver box. May have a damaged or pinched receiver wire. My servo wires were crimped on the rubber seal.
    Lexington, SC
    2,173
    Quote Originally Posted by Louie L View Post
    First thing I would check right there! Also, have a friend look at the LED light on the receiver when out of range. Should turn red or blink red if it has lost connection with the transmitter.
    Jeremy
    Jeremy
    Feb 2013
    Courtice
    38
    Quote Originally Posted by ponie1992 View Post
    Jeremy
    U can c the wire in the tube (c in the picture)
    Feb 2014
    22
    the wire is halfway thru the tip, i pulled it about 1inch, i will see later if it works, meanwhile i wrecked it last night and broke the left swing arm, ordered the alloy front and back will arrive tues.
    i am fixing the broken arm so i can ride it temporarily,, easy fix.
    i just want the alloy better. thanks guys!
    Mojave Desert
    1,613
    which aluminum arms did you purchase?
    Lexington, SC
    2,173
    When working correctly, the wire length has minimal effect on range. I have receivers with chewed up wires and the range is still well over 100 feet. It's a faulty receiver.
    Jeremy
    Jeremy
    Feb 2014
    22
    Mojave Desert
    1,613
    oh ok yea i seen those on ebay.
    Feb 2014
    22
    the amazon ad says it's for Traxxas XO-1....but the dimension says 1x1x1 and 4.8 ounce....hope they are telling the truth that it's indeed for XO-1
    Jan 2014
    S. Carolina
    14
    Traxxas uses the same A-Arms for multiple vehicles. That looks to be the correct one.
    Feb 2014
    22
    easy fix!... will use this while waiting for the new arms to arrive next week
    Jun 2013
    Ontario, Canada
    259
    How well did your "QuickSteel" hold up? I bought some but have never used it, though I have used Magic Putty- a similar epoxy putty stick but it tends to stick to itself very good but not to other things!
    Feb 2014
    22
    the quicksteel holds up really good,, i used to be a jb weld fanatic but when i used quicksteel once, i fell inlove with it, its very user friendly. cures in 5minutes and you can mold and shape it however you want.
    i rode my xo-1 on a very rough road yeasterday in san diego and that swingarm repair is still very intact.
    but, my alloy swingarm replacement came yesterday night so i installed it rightaway. nice i loveeet
    101
    Take your car back from where you got it.. I've seen this issue alot, and what happens is from the factory the reciever wire gets pinched underneath the waterproof reciever case ultimatly causing a short in the attenna wire.
    Once this happens, its hard to correct with out getting a new reciever, But being that it was like that when you bought it. The dealer that sold it to you should replace it for free... Same problem happened with one of mine
    Quote Originally Posted by robster888 View Post
    one wrong hit and those will bend, I've went through it. If you ever have to repurchase any type of Control arm get the rustler Aluminum Control arms from Fastlanemachine.net Rustler control arms are a direct fit
    Feb 2014
    22
    Really appreciate your inputs bdion, as a beginner, i really know nothing much about RC's yet, this forum and you guys give me a real big help.
    i noticed on this video http://youtu.be/L3Wsd1rBYX8 the range of the car from the transmitter is really far, is it how its supposed to be out of the box? or o you think the owner upgrade his TX or RX to a better one??...do you guys have any suggestion on which is the best Transmitter or reciever that i can install to get the longest range and without interruption?.
    thanks for the input on about the swingarm also..
    and how easy or quick is it to return something from AMAZON?? my first time...thanks
    Lexington, SC
    2,173
    My cousin has a couple Spectrum tx/rx's and he has found the Traxxas tx/rx's give him better range. I have had no issues with Traxxas stuff thus far.
    Jeremy
    Jeremy
    101
    Robster88 im going to PM you my phone number if you can throw me a call and ill be able to explain things slightly better
    Feb 2014
    22
    hi guys,,, so the new reciever arrived and i installed it, i did the binding procedure and both green light are on,,,the steering is working but it doesnt want to go forward or reverse...the ESC keeps on beeping. red and green light blinks alternately.
    i did the reprogramming too but still forward and reverse does not work...
    thanks for the help
    Feb 2014
    22
    nevermind guys, i had it running now,,i connect my iphone to the tX then it registered the newly installed Rx...and both steering and ESC are working now...hmmm,it's a fine machine after all...
    bdion,got ur number, i'll call you soon if your'e not busy. i need some tips from the pro. thanks again!
