    Feb 2014
    USA
    14
    Differential clicking?? Frustrated.
    Took everything apart and the clicking is coming from between the spider and output gears. Upon visual inspection at first, nothing looked worn. Plenty of lubrication. Re-assembled and it went away for a run or two. Now it's back and getting worse and the rear is starting the same thing. What's the deal with the diffs in these things? I haven't been pushing the car real hard, just driving around in the living room with stock battery/motor. Should I spend the money for the aluminum spools front and rear? Can you put the spool in the rear? Should I just get stock diff replacements and shim something? So many parts for this are out of stock. Don't see how this could hold up long with any kind of power upgrades. I had pre-ordered the Teton because I really liked my Rally, but now I am second guessing this 1/18 platform. Maybe I should cancel that pre-order and part this thing out in an online auction...
    Dec 2013
    37
    Stock diffs are a problem if not shimmed. The spools can beat up on the shaft pinion gears. If you can use the 2 geared diffs to rebuild one of them, put it in the front and shim it. Sometimes it helps to shim the driveshaft pinion as well. The spool in the rear should be fine if you're running on smooth surfaces (indoors, or polished concrete).
    Feb 2014
    USA
    14
    Thanks for the reply! I only plan on running this indoors anyway so I'll probably just get the spools front and rear and hope that works. That is still about $30 for two of those and the car only cost $130. Hmm.. maybe I can JB weld the diffs together to make a solid axle..hahaha
    Riverton Utah
    4,361
    Quote Originally Posted by drumbum View Post
    The Teton comes with metal gears, not plastic so they will be quite a bit tougher. One of the reasons your diffs could be clicking is the bushings that they ride on are worn out, allowing for the gears to move around, thus making the sounds your hearing. Hope this helps!
    Feb 2014
    USA
    14
    I knew I would be upgrading to bearings when I purchased the car and have since ordered them, but it is just a waiting game for all the parts I'd like to have for it. Guess I'll just be patient. I hope once the Teton comes out next week all this stuff is easier to get.
    Riverton Utah
    4,361
    Me too... I can't wait to get the Teton! I was waiting for the bearing kit to be released. I got tired of waiting so I just made a bearing kit from Avid. Only $1 per bearing! Out of curiosity, what color did you pre order, from what website?
    Feb 2014
    USA
    14
    Orange from Tower. Had to get a color I didn't have on any of my other vehicles. Also, I see on the Rally gallery page they now show it in orange too, instead of yellow..
    Riverton Utah
    4,361
    Wow! That's odd! They even photo shopped the pictures of the yellow ones orange! I bet the yellow shells are going to be really valuable now!
    Feb 2014
    Arkansas
    185
    This is happening to me as we'll. I've converted my rally to a brushless system and after putting a lipo battery on it, the front diff has been clicking everytime it starts to build up speed, when you pick the car up and just let the motor go, everything's fine.
