Results 1 to 30 of 30
    Jan 2014
    78
    MERV broken antenna
    Today i let my friend use my MERV. He rolled it over on his first try. No damage except that the antenna straw broke. We superglued it then went right back to driving. It broke again so he tried to pull the straw off. Bad idea. The straw was glued to the wire, and the wire snapped right off. What replacements do I need?
    12,291
    It may be fixable.
    The antenna is a coaxial wire... and only the last little bit (3cm) is used to receive signal. If you are careful and remove the black covering and the wire net of the wire you might be able to fix it.
    Or... just buy a new receiver.
    Jan 2014
    78
    where could i get a new receiver box
    i tested it and the car can only go about ten feet.
    12,291
    Right... that is because of the antenna damage.
    Do you need a new Rx box too?
    Hobby shop, eBay... wherever you like to shop.
    Dec 2013
    WI
    432
    Quote Originally Posted by MERV123451 View Post
    Yeah that's all you need really is that short piece of exposed wire. Where did the wire break off though?
    Jan 2014
    78
    At the bottom but I already ordered a new reciver
    Jan 2014
    19
    do you have a soldering iron? If so you can look at soldering a new one on that's what I did and you can just have an extra receiver
    MERV, Team Durango DEX210
    Jan 2014
    78
    I don't have a scolding iron. Does anyone know how to or at least a video of installing a new receiver?
    12,291
    I haven't seen one... it is super easy.
    Remove old receiver
    Unplug item from old, plug into new
    Bind according to the instructions in your manual
    Stick everything into the Rx box
    Candiac, QC
    166
    My son's mini slash antenna is broke also...we lost the little end piece you're all talking about in the snow...so I had to order the receiver. Why is the darn think so long??? My summit has an antenna that doesn't even stick out when i use the E-Revo body...
    Any way to shorten it? the cut and solder approach? or can I just stuff/pull/tuck most of it back in the receiver box? Want to keep the range...
    Don't believe everything you think!
    Long Beach, California
    6,883
    I bought this receiver like this
    cause I did my other receiver by peeling off the black skin then behind the black skin is a braided wire loom do the same by removing it but with extra careful cause behind it is the actual wire, just copy the length of the actual wire tip.
    heres my other reciever next to the one I just peeled off.
    | Rally GT8 Powered By CC |_________________ |
    12,291
    Quote Originally Posted by Francis de Gruchy View Post
    From what I understand, Traxxas may have put weaker parts in the long antenna ones to save some money. The weaker parts means weaker signal which means the longer antenna is needed to get any distance on the range.
    Some have, however, shortened the antenna TUBE and coiled the extra antenna length in the Rx box without any ill effects on range.
    Candiac, QC
    166
    Cool thanks Jimmie
    Jan 2014
    78
    Does coiling it in the rx box work? I just installed it and the antenna is awfully long. I'm afraid if I roll over it will break...
    Candiac, QC
    166
    coil it in, and try it. Jimmie above said some have done it and it seemed to work. That's what i'll do.
    Jan 2014
    78
    Thanks i just did it. Should I have the antenna tube sticking a little out of the body or under the body and not visible
    Candiac, QC
    166
    your choice man, but if you want it protected, leave it under the body. As i wrote above, my summit antenna tube is about 2 inches and does NOT stick out of the body, so why should it stick out of the slash?
    Look at this picture of my summit (shell off), it's the little blue tube you see between the motor and the right rear tire. It came this way.
    It even tucks under the low-profile BAJR body - see it?
    Candiac, QC
    166
    and i get at least 200 yards range!
    12,291
    Your radio is a lot different than the radio he is dealing with. It may not get any range with the antenna tucked under the body.
    I wouldn't cut the tube until you range test it everywhere you run your RC.
    Jan 2014
    78
    I've decided to leave the tube about a centimeter over the body. I will test the range and if it's same as new, then I'll try to put it under the body
    Candiac, QC
    166
    Trust Jimmie - I'm a relative noob
    Jan 2014
    78
    that bajr body looks AWESOME
    12,291
    Agreed.
    I want one!
    Candiac, QC
    166
    JConcepts, but please note this is installed on a 1/8 Summit. It will look similar on E-Revo and it's really marketed for Slash/Slash 4x4.
    I' ve seen something similar on a 1/16 revo using the axial Hardline Body:
    http://www.axialracing.com/products/ax04026
    See other threads on traxxas online for it; i'll try post it
    Candiac, QC
    166
    Here it is
    Candiac, QC
    166
    Don't let yourself be limited by wht the sites say "this body is for so-and-so", most bodies can be adapted...jut use common sense, a 1/8 scale body will not fit 1/16, except if you're looking at a sninny axial crawler body like this on maybe a MERV.
    Like forget about a XO-1 body on a Summit...wait...My spider senses just started tingling...
    Edited for language abuse. If you see a starred out word in your post, you must edit it out to avoid earning warning points.
    Jan 2014
    17
    What kind of tires are those! They look exactly like Mickey Thompson Baja claws
    12,291
    Jan 2014
    78
    Geez overpriced 200 FOR AN RC CAR WHEEL?!?!?
    Candiac, QC
    166
    Plus 90 beans for the tires
