Thread: Problems
    Dec 2013
    201
    Problems
    When I try to charge my lipo batteries all it says is connection break. I've tried with 5 different batteries and none work. Please help.
    Sep 2009
    Victoria B.C Canada
    5,073
    Connecters all good solid connection between batt and charger?
    balance plug connected securely?
    Sent using lipo power
    Mountains cant stop me
    they have tried
    Dec 2013
    201
    Yes I've connected and re connected everything multiple times
    Traxxas Employee
    Aug 2013
    74
    Both the main battery connector (black) and balance connector (white) need to be plugged in in order to charge a LiPo battery. If one of those plugs is not connected it will give you that error.
    If it is connected properly and still gives you that error, then you may have a broken connection in the battery or charger. If that is the case, give customer service a call for further assistance.
    Dec 2013
    201
    The main battery connector is the traxxas high current connector?
    Dec 2013
    201
    Thanks clay shredder That did the trick. Do you know where I can get the battery harness with a deans connector?
    Dec 2013
    201
    Never mind found it on ebay
