Results 1 to 17 of 17
    Jan 2014
    South NJ
    224
    1/16 E-Revo Waterproof Metal Geared Servo
    i am looking for a waterproof metal geared servo for my mini e revo the traxxas one broke and i am trying to find a waterproof replacement so that i can still run in the snow
    Sep 2011
    Iowa City, Iowa, USA
    1,667
    Get the blue bird 390 then wipe silicone cauld in the cracks.
    Sent from my SCH-R970 using Tapatalk
    1:16 Slash VXL
    Stampede 4x4 3800kv
    Rustler VXL
    Alma, Michigan
    12,290
    It is super easy to waterproof a servo. I have gotten waterproofing a servo down to about 5 minutes of work... all it takes is some time, a little RTV sealant, and a dab of dielectric grease.
    Disassemble the servo, put a dab of grease where the servo spline pokes through the case and reassemble with RTV at the seams. Once completed, it will look just like a standard servo.
    The most popular servo replacements are:
    $40ish HiTec 5085
    -- Requires a different horn. Some use the included horns and modify them to work. Others feel a $10ish aluminum horn is needed. Some have also felt that the install required custom linkage to retain stock steering geometry. All but 1 gear is metal.
    $30ish Blue Bird 390
    -- All stock hardware can be reused... the stock horn bolts right on. This is the servo I used in both of my 16ths for 200 or so packs before I sold them and are still going strong today. All metal gears.
    $10ish Corona 238
    -- I have not done a whole lot of research on these... but I belive all stock hardware can be used on this one too.
    Vassalboro Maine
    206
    [QUOTE=Jimmie Neutron;
    $10ish Corona 238
    -- I have not done a whole lot of research on these... but I belive all stock hardware can be used on this one too.[/QUOTE]
    yes all the stock hardware can be used.
    Blue 1/16 summit vxl crawler
    Jan 2014
    South NJ
    224
    will the servos not break with my proline titus 2.2 rims and trenchers wheels they are heavier and bigger than stock
    Alma, Michigan
    12,290
    It has a lot better chance of surviving than stock, that is for sure.
    Jun 2013
    LaConner, WA
    202
    Stay away from the corona servo. I put one in my rally and it clicks every time I turn full left. I have centered it properly. While looking at it tonight and turning the wheel left it clicked and I can see the plastic case spreading apart on left turns. So get a servo that has aluminum case.
    $40ish HiTec 5085
    $10ish Corona 238
    Jan 2014
    19
    I love the hitec5085 it is a great servo and it really isn't that hard to make a servo horn out of what they give you plus it is super fast!!!!!
    MERV, Team Durango DEX210
    Jan 2014
    78
    Get a hi-tec metal gear waterproof servo
    They don't dissapoint
    Jan 2014
    78
    This one is great, fast, and very very powerful http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Oct 2013
    194
    Quote Originally Posted by MERV123451 View Post
    I would assume this one is too big and you meant this one -
    http://www.ebay.com/itm/NEW-Hitec-HS...item43c3d27342
    But wow they are expensive...
    Jan 2014
    South NJ
    224
    i was going to say the same thing the stock servo is 29.5x14x29mm
    Jan 2014
    78
    Nah i have it its for 1/16
    Alma, Michigan
    12,290
    The one you linked to will not fit in a 16th.
    Here are the specs on the stock servo:
    Measurements: -LxWxH- 1.20 x 0.55 x 1.10 in (30.514.027.9 mm)
    Here are the specs on your linked servo:
    Measurements: -LxWxH- 1.65 x 0.83 x 1.57" (41.8 x 21 x 40mm)
    Not only the size is too big, but the mounting tabs are incorrect as well.
    Jan 2014
    78
    Waaait you WERE right
    Jan 2014
    South NJ
    224
    that is weird cause the measurements that i is for the stock servo that i found on amazon.com i looked up traxxas 2080 servo
    Alma, Michigan
    12,290
    Here is where I got my specs from:
    http://www.servodatabase.com/servo/traxxas/2080
    Not like they are miles apart though.
