    Feb 2013
    37
    Sidewinder sct issue with traxxas slash and rustler
    Hi everyone I have just purchased 2 sv3 sct combos from castle. I have installed them into my slash and rustler. The problem is I only have steering in the rustler and steering with a bit of very low speed throttle with the slash the throttle then wears off after about 20 seconds then does not work at all. I have tried different batteries and have researched the problem online but cannot figure it out any help would be greatly appreciated. Thanks
    Jan 2005
    Nuclear Power Plant drainage ditch
    2,715
    What kind of batteries do you have?
    The Castle systems require a ton of amperage from the battery. Almost all NiMh batteries will not work. You need lipo with at least a 25C rating and at least 4,000mah rating. Higher C and mah ratings are recommended.
    All those who believe psychokinesis raise my hand
    Feb 2013
    37
    I did try a 3s lipo pack with 30c and that didn't work.. Same results as the stock nimh pack
    Jan 2005
    2,715
    Quote Originally Posted by Traxxas_Slash_VXL View Post
    Hmm. Try to reprogram the the ESC and make sure it's set to Lipo. If that doesn't work, contact Castle.
    I know for sure it won't run on the stock 7-cell 3000mah NiMh Traxxas battery. On mine it putted and sputtered and stopped.
    Feb 2013
    37
    Non-Traxxas support question removed. You need to contact the manufacturer of your battery pack, as this sort of product support is not permitted here. -cooleo
    Mar 2003
    Wherever the road takes me.
    36,801
    If you need help with your non-Traxxas ESC, you're going to have to contact the manufacturer of that ESC. Product support for non-Traxxas products is not permitted here.
    Thread Closed.
