Results 1 to 13 of 13
    illinois
    527
    Traxxas lipo charger
    Yes i know a lot of responses will be to get a faster charger, but for now I'm good with the traxxas wall lipo charger (as long as it works correctly).
    My question is I'm not sure if the charger or the battery is messing up. is there a way to figure out which one is messing up. Im charging a 2s spc 5000man and it seems to charge fine and when the one cell is fully charged the other stays red n will continue to do so the entire night if i let it. but if i unplug it and plug it back in, it stops charging and goes to a green light saying its fully charged.
    Let's Get Dangerous - "DWD"
    Oct 2013
    Thousand Oaks, CA
    395
    Do you have another lipo charger to test?
    Go Traxxas, Team Associated, and Losi!
    illinois
    527
    nope - i was wondering if others had encountered the same thing with there wall charger. if not then most likely to me it'd be the battery then.
    Quote Originally Posted by Traxxasfreak61 View Post
    Oct 2013
    Thousand Oaks, CA
    395
    Does the battery act normally when you run it, and also try a friend's charger to see if it does the same thing.
    illinois
    527
    don't know of anyone else around that has an rc muchless a lipo charger - nearest track 2 1/2 hours away
    greenwood cemetery bashplex 8))
    12,355
    Volt meter. Before blaming the battery, you MUST at least read the voltage after charge. I would hold off on using that charger again till you find out if its not doing its job. If the battery is bad, chances are the 5$ charger did it.
    Whats in my wallet?
    I cant afford a wallet...
    illinois
    527
    thanks i will pick up a volt meter
    illinois
    527
    Just bought a new duratrax lipo charger n a new spc 2S 6500 65C battery
    illinois
    527
    What r the odds the new charger balances the old battery back out
    12,355
    If the battery was not damaged by 1 cell being discharged too much, chances are pretty good. The battery has not swelled up has it?
    Whats in my wallet?
    illinois
    527
    no swelling - it just didn't look like it was going to stop charging the one cell the light didn't turn green unless u unplugged it then plug it back in - haven't run it yet - so it shouldn't have overly discharged
    12,355
    Sounds like you are ready to go as soon as you check that the cells are balanced with a voltmeter, or on your new chargers screen 8)
    Whats in my wallet?
    illinois
    527
    yep new charger is here and it charged up and balanced itself nicely.
