Thread: 6s
    Nov 2013
    19
    6s
    Has anyone tried some spc 6s on a stock summit setup?
    Would it even work?
    Lehi, Utah
    1,328
    Can you even run a battery that big with out damage? And I'm pretty sure they won't fit in the battery trays anyway.
    Slash 4x4 built from Proline RPM STRC TRX and MIP
    15,586
    The Summit's EVX-2 has a 4S limit.
    SPC does not sell 6S packs.
    Alt-248 on the number pad =
    Lehi, Utah
    1,328
    That's what I thought.
    So how does the EVX-2 work? Does it run the batteries in series or parallel? And what does each mean?
    Nov 2013
    19
    I mean two 3s batteries total of 6s
    Spc now sells 3s and 4s but apparently it wont work either way
    Nashville, TN
    1,784
    You could do it with a different speed control, but 6s would cook the stock motor. If you needed a smoke machine in a pinch, that'd make a good one.
    15,586
    6s
    With the EVX-2, the batteries are wired in series internally.The BEC side should not be powered with battery packs having a greater cell count than 2S. Pre-LVD-enabled models would run 5S total but this was outside their specs and doing this would likely void the warranty.
