Results 41 to 80 of 95
  1. #41
    Alma, Michigan
    12,290
    Sounds like the servo fried, taking the ESC down with it.
  2. #42
    Dec 2013
    Philadelphia
    61
    Quote Originally Posted by OgreKing View Post
    Hey guys. I have a stock brushed Ford Fiesta that I run on qty 2 Traxxas niMh (stock batteries) and of course, using the Traxxas parallel connector. I wanted to have more drifting action so I added a strip of electrical tape on the wheels. After 5 minutes of play, the car AstoSpepped, ESC was no longer responding and emited smoke, and my steering servo stopped working and now shows a curious hole in its side as if something punctured it from the inside-out. Can anyone tell me what happened ?
    Sounds like u can use a stronger ESC other then the stock one. I'm not sure.
  3. #43
    Dec 2013
    Philadelphia
    61
    Hey jimmie since I'm changing the motor. I need a tool set! Any suggesting?
  4. #44
    Alma, Michigan
    12,290
    Bondhus 10666
    http://www.bondhus.com/bondhus_produ...vers/ball.html
    That is what I use.
  5. #45
    Dec 2013
    Philadelphia
    61
    Thanks.. Whats a good traxxas 3s lipo to use on the SV3 ESC?
  6. #46
    Alma, Michigan
    12,290
    Is that a trick question?
    There is only 1 3S Traxxas LiPo that will fit.
  7. #47
    Jun 2013
    LaConner, WA
    202
    I started smoking ESC and motors. New motor and sv3 ESC and couldn't get it work. Unplugged steering servo and ESC responded. Upgraded servo and Car is working but still trying to get radio / ESC programmed. So you ESC is toast. Once you let the smoke out, you can't put it back... and your stock servo, toast. Upgrade both and to.
  8. #48
    Dec 2013
    Philadelphia
    61
    LOL no it wasn't a trick question... I thought you might of had a different type of battery in mind that
    you can suggest other then the traxxas one... How about that SPA battery u were talkin about... would any of them fit the stock adapter or I might have to do some modding?
  9. #49
    Dec 2013
    Philadelphia
    61
    so my car should be here by this weekend... I bought a 2s battery with a 380 brushless followed by a castle sv3 ESC..
    motor mounts motor plates and gear covers/HARDWARE. A pair of HPI RACING WHEELS & HIGH GRIP RUBBER TIRES (hpi)
    Size 2.2 with a 3mm offset. White 6 spokes with a chrome lip.
    And i order a pro line rally shell with some RC changing paint ORANGE/PURPLE/RED AND A CAN OF CLEAR COAT.... I'm waiting on some more funds so I can upgrade my motor and ESC... Then I'm off to get the XO-1
  10. #50
    Alma, Michigan
    12,290
    Yes, SPC has a 3S pack for the 16ths... you just asked "traxxas 3s lipo".
  11. #51
    Dec 2013
    Philadelphia
    61
    Lol my fault... I was rushing when i type that... Im going to check them out... there is something else I wanted to know. Aye jimmie I just want you to know that you basically put this car together... I'm just on the labor end of things lol...
  12. #52
    Dec 2013
    Philadelphia
    61
    I wanted to know whats a good spur for a 12T pinion? Would the stock 50T spur work?
  13. #53
    Alma, Michigan
    12,290
    That is a pretty small pinion, but yes... the 50t spur will work.
    Keep in mind that the perfect gearing can only be figured out by you... and a thermometer.
  14. #54
    Dec 2013
    Philadelphia
    61
    Jim i just got my esc but it didn't come with any wires to connect to the motor. So what's the next move??
  15. #55
    Alma, Michigan
    12,290
    Does the ESC have female bullets?
    Do you know how to solder?
    Does the ESC have a battery connector installed?
  16. #56
    Dec 2013
    Philadelphia
    61
    http://www.amazon.com/gp/aw/d/B00AQY...H96KKuZs//2Q==
    This is exactly how it came... I have to solder the power line i see but what about the three wholes for the motor?
  17. #57
    Alma, Michigan
    12,290
    Holes.
    You may need to make up some extensions for the motor wires. The ESC probably takes 4mm male bullets (not banana plugs) and the motor will plug into 3.5mm female bullets.
  18. #58
    Dec 2013
    Philadelphia
    61
    does it matter what slot I plug the motor cores in?
  19. #59
    Alma, Michigan
    12,290
    Not really... well, sorta. One way will be backwards, the other forwards... if you try one way and it is backwards, switch any two.
  20. #60
    Dec 2013
    Philadelphia
    61
    http://www.amazon.com/gp/aw/d/B00ECO..._s_a_1_fkmr0_1
    These should work with the 4mm bullet connector?
  21. #61
    Dec 2013
    Philadelphia
    61
    http://www.amazon.com/gp/aw/d/B001C3...UBYqVKlAf/2Q==
    This is a 4mm male/ 3.5mm female adapter (not banana)
  22. #62
    Alma, Michigan
    12,290
    The last link you provided says bullet, but shows banana. I would confirm that they are indeed bullets before purchasing... but that is exactly what you would need to get going.
    The reason I state bullet and not banana is because of amperage capability. Banana connectors are not very good for high amperage situations do to their lack in surface area contact. Only the very outer curve of the thin strips of metal are making contact when slid into place.
  23. #63
    Dec 2013
    Philadelphia
    61
    Thanks bro... I'll check harder
  24. #64
    Dec 2013
    Philadelphia
    61
    Hey Jimmie i receive my car and i love it... To bad i can't mod it yet. Because i Was testing it out on the 2s lipo and i ran over rock and it made the car flip right into the sewer hole. Smh i was super mad. But i ordered another one. I wanted to know if the velineon 3500 fit the revo mount u suggested for the 380 Brushless???
  25. #65
    Alma, Michigan
    12,290
    No it will not... you would need the following:
    $8 Motor Plate (7380)
    $4 Gear Cover/Hardware (7379)
    $10 Motor Mount (7360)
    $10 Rx Cover (7024x)
    This is a picture of the difference in Rx covers:
    New style (for big block) is on top.
    Unless you have an OLD 16th, you probably have the new style box.
    Plus a bunch of handling improvements to counteract the much higher center of gravity of the bigger motor. Handling goes out the window when swapping in something bigger.
  26. #66
    Dec 2013
    Philadelphia
    61
    Would that gear set come from a Traxxas 1/16 Grave Digger ?
  27. #67
    Alma, Michigan
    12,290
    Gear set?
    What gear set?
  28. #68
    Dec 2013
    Philadelphia
    61
    I was referring this the mounts and plates & ect.... What car would this set come from
  29. #69
    Alma, Michigan
    12,290
    Any 16th that came with the Titan 550.
  30. #70
    Jun 2013
    LaConner, WA
    202
    I lost sight of my rally and it ended up fully submerged in an South carolina sewer drain. Ran to my shop for crowbar to pull lid, fished car out and disconnected battery. Threw it on the shelf for a couple months to dry out. Put a a battery in it and it ran fine. Rice will absorb moisture too. if you place it in a bag. I suggest lubing everything before trying though
    Quote Originally Posted by Streetz Daddi View Post
  31. #71
    Dec 2013
    Philadelphia
    61
    Quote Originally Posted by gorilla2891 View Post
    My poor little fiesta gone... I lift the lid and didn't see it. i didn't bother to fish it out. I just order and one and I'm trying to see how to fit the velineon 3500 in it
  32. #72
    Dec 2013
    Philadelphia
    61
    Is this the kit that u were talking about would fit the velineon 3500
    http://m.ebay.com/itm?itemId=400611085606
  33. #73
    Dec 2013
    Philadelphia
    61
    Heyy so i got my car out the sewer hole lol it stinks so bad lol.... Anyway i wash it off good and disconnect everything and placed in a box with a big bag of rice.. I have the car buried in rice lol and i sealed the box closed. Hopefully it still works
  34. #74
    SE Texas
    1,178
    Did you dissassemble everything?
    Most parts should just need to be cleaned.
    I'd bet your receiver is probably toast and will need to be replaced.
    Motor/esc and servo(if stock) are waterproof and should be fine.
    As for the transmission and gears...a good cleaning and greasing and they should be ok.
    "Dude,I almost had you"
    R.I.P Paul Walker
  35. #75
    Dec 2013
    Philadelphia
    61
    Quote Originally Posted by dcfox View Post
    Motor/esc and servo(if stock) ate waterproof and should be fine.
    I definitely fried my receiver! It don't work so I ordered a 5 channel receiver instead of the stock that comes with it.. Plus i order an additional servo plus the dual steering attachment. I don't even want to use the stock motor or the ESC so I replaced the motor with a 380 BL and the ESC with castle sv3... I'm just waiting for parts now
  36. #76
    Jul 2012
    Yakima, Washington
    1,422
    Using two servos is quite hard without adjustable links because they will kill each other while trying to get centered.
  37. #77
    Jan 2014
    South NJ
    225
    not if you center both servos i have a losi mini lst with dual servos and replace them one time with some hitech ones and they work great for that truck just need to know what you are doing when you do dual servos
  38. #78
    Dec 2013
    Philadelphia
    61
    wassup rc people's! well i hooked up my two servos. i centered them perfectly. everything is working fine. so do anyone know how to disable the LVC????
  39. #79
    Dec 2013
    Philadelphia
    61
    by the way... im working on a 4s setup for my rally/fiesta. I'm running the mini revo stock setup with a Castle Creation CC BEC. i seen people run 4s on that stock esc/VXL 3M. currently I'm ruining a Castle Creation Sidewinder 3 ESC it's nice but will not accept 4s to save my life.
    is there any 4s set-up fans out here ???
  40. #80
    Alma, Michigan
    12,290
    The 3M will only do a few speed runs on 4S before frying.
    There is a new ESC that came out recently... Castles Sidewinder 8th. You may want to look into that for 4S running. From the specs it sounds like a very good match to what you are wanting.
    Turning on/off LVC is in here:
    http://traxxas.com/sites/default/fil...0-121204_4.pdf
