Results 41 to 80 of 85
  1. #41
    Dec 2013
    87
    Quote Originally Posted by summitbasher240 View Post
    IDK if you have any, but if not LIPOS!!!
    I have 3 lipo batteries and I'm probably getting 2 more soon
    LEFT TURN ONLY
  2. #42
    Land o' flat.....
    1,100
    Glad to hear. I hate when you hear people not using lipos because they think there dangerous.
  3. #43
    Dec 2013
    87
    I've heard about fires with them but I've never really thought much about that
    I got my mip driveshafts in
    LEFT TURN ONLY
  4. #44
    Lehi, Utah
    1,330
    ^^ yay! Now time for the fun part. Install.
    I don't know why people are so scared of lipos. Yeah they can cause fires but their not as temperamental as people think. And plus you hold them in your hands and put them on your face everyday.
    Slash 4x4 built from Proline RPM STRC TRX and MIP
  5. #45
    Dec 2013
    87
    Got them installed too. Everything is SOOOOOOO small
    I got some p-l masher 2.2 tires and rpm revolver wide wheels. Got extended body mounts too
    LEFT TURN ONLY
  6. #46
    Nashville, TN
    1,789
    Mod1 gears may be a good investment, but 32p should still work fine.
    If you're using the LCG chassis, and don't have a chassis brace, the tekno big bone is a necessity when you run a mamba monster combo and large battery. All the extra weight with bend the center shaft quickly on impacts. The big bone acts as a chassis brace. The standard chassis doesn't need it though.
    I'd add some heavier shock springs to your list. All the extra weight is too much for the stock springs.
    Velcro is the way to go. Get a roll of double sided Velcro, cut some slits in the chassis beside the battery compartment, and you can put whatever size battery in there you want. On all my traxxas trucks, I remove the stock battery holders and install Velcro straps.
    Oh, a few more things:
    - a castle field link card
    - a servo y-adapter extension
    - stronger steering servo
    The mm2 fan has it's own connector separate from the ESC. Both it and the ESC have to plug into the receiver. Using a y-adapter (or just two servo extensions), and letting the ends hang out of the receiver box, is the easiest way to quickly hook up a castle link card and remove the fan if needed. Everything's still waterproof too. Otherwise it's a pain to open the receiver box each time you want to make a change.
    The stronger steering servo isn't really needed, but it helps a lot.
  7. #47
    Dec 2013
    87
    I have all aluminum stock sized shocks with big bore springs how much does a y adapter cost?
    Do you know gearing and how fast can I go on 6s?
    LEFT TURN ONLY
  8. #48
    Nashville, TN
    1,789
    Y adapters are pretty cheap from some online stores. Not sure which ones I can mention, so I'll just say google it.
    The stock springs on the aluminum shocks are probably not stiff enough. You'd likely need to go a step up in stiffness. Otherwise you'll be using lots of shock spacers to get the ride height right.
  9. #49
    Dec 2013
    87
    I have 2.5lb stiffness springs stock are 1.5 I'll see about that y adapter I might wait before I get it
    What about speed?
    LEFT TURN ONLY
  10. #50
    Nov 2013
    Iowa
    398
    should be right around 80 geared 22/50
    Slash 4x4 MMP/2800kv
    Slash 4x4 LGC MM2/2650kv
  11. #51
    Dec 2013
    87
    Us that gearing fine for bashing too? My gearing is 12/54 right now
    LEFT TURN ONLY
  12. #52
    Jul 2012
    Mesa az
    370
    Srry about not getting pics up I'm waiting for some shocks to install then I will have some it's very easy. 22/50 is for speed runs for me and it gets pretty hot bashing around not doing high speed runs. What motor are you gonna use I run 19/54 with my mmp 2400 and it's perfect I could even go up to a 20 on the pinion but I don't have one.
  13. #53
    Dec 2013
    87
    I running a mamba monster 2 motor and esc combo 2200kv
    I have another spur assembly so I'll use that for speed runs. I'll use the one in now for bashing.
    Speed: 22/50
    Bashing: 12/54
    LEFT TURN ONLY
  14. #54
    Jul 2012
    Mesa az
    370
    Quote Originally Posted by impulse43 View Post
    Speed: 22/50
    Bashing: 12/54
    12/54 is not gonna be fun. I guarantee your gonna be bored the first time you run it. Your gonna want a 20/54 or higher with 52 spur
  15. #55
    Dec 2013
    87
    So I use 20/54 for bashing?
    LEFT TURN ONLY
  16. #56
    Jul 2012
    Mesa az
    370
    Just depends on where you run it the best would to be get pinion gears from 17-25 I would think and get spurs from 50-54 then run the different ratios and see what works the best for you and if it runs cool enough for you fast enough etc.
  17. #57
    Dec 2013
    87
    I have my motor esc and receiver installed I think I'll try 19/52 first for bashing and 22/50 for speed runs. I should be testing before the end of the week.
    LEFT TURN ONLY
  18. #58
    Nashville, TN
    1,789
    Just leave the 50t spur in there. No sense in changing it all the time when it'll make minimal difference compared to changing the pinion.
  19. #59
    Dec 2013
    87
    I'll try that but taking out 4 bolts don't bother me. I have two gear assemblies.
    LEFT TURN ONLY
  20. #60
    Dec 2013
    87
    Does anybody know if Turn!gy batteries are any good just found a 3s LIPO for about $20.00, but it has a xt60 connector. Can I change that?
    LEFT TURN ONLY
  21. #61
    Nashville, TN
    1,789
    Can't talk about those here. I, along with many others here, would recommend SPC lipos.
  22. #62
    Land o' flat.....
    1,100
    Many others......
  23. #63
    Nov 2013
    Iowa
    398
    Forbidden fruit, but you can change any Lipo to the connector you want you could even buy an adapter if you can't solder
  24. #64
    Dec 2013
    87
    Oops I forgot about that
    LEFT TURN ONLY
  25. #65
    Dec 2013
    87
    I have all my aluminum parts installed
    LEFT TURN ONLY
  26. #66
    Nov 2013
    Iowa
    398
    Photos please
  27. #67
    Lehi, Utah
    1,330
    Please!
  28. #68
    Jul 2012
    Mesa az
    370
    Here you go it's fairly simple to do so. Just get cardboard lay it in the battery tray cut it to shape get thin metal or aluminum plate mark where the holes are get the screws that we used with the stock battery strap get nuts then there you go hers my pics
    [IMG][/IMG]
  29. #69
    Dec 2013
    87
    Sorry for the delay I am going to take some pictures in just a minute
    LEFT TURN ONLY
  30. #70
    Dec 2013
    87
    I can't figure out how to post pics from my camera roll any help?
    LEFT TURN ONLY
  31. #71
    Apr 2013
    Burnaby BC
    87
    Quote Originally Posted by Jws1982 View Post
    ^^^^^ Concur!!!
  32. #72
    Lehi, Utah
    1,330
    You need to upload your pictures somewhere online like photo bucket or something and then click the incert photo button above and paste the URL and it should work.
  33. #73
    Dec 2013
    87
    Can I do it without making a account on another website?
    LEFT TURN ONLY
  34. #74
    Nov 2013
    Iowa
    398
    use Tapatalk on your cellphone its a free app
  35. #75
    Jun 2006
    Austin, TX
    264
    sorry for butting in but why can't we talk about certain brands of lipos such as ******* but CAN talk about SPC? Thanks
  36. #76
    Land o' flat.....
    1,100
    Because that company stole Traxxas Design ideas. Since this is a Traxxas Forum, Traxxas has banned speaking about or referring to that brand.
  37. #77
    Dec 2013
    87
    Quote Originally Posted by cmistac View Post
    I'll try to get that soon
    LEFT TURN ONLY
  38. #78
    Dec 2013
    87
    could i upload pictures to a computer? I tested it out with 18/50, 5s lipo battery. it ran fine. Can I hit 80 mph with that? Anyone else tried ice drifting lol? It doesn't pop wheelies like on the videos I saw. how do I pop them?
    LEFT TURN ONLY
  39. #79
    Aug 2012
    Saginaw,MI
    327
    snow chains or possible ice studs, I can pull a wheelie on ice with snow chains on 2s mashers 2.2 and velineon esc, heres my thread, it might help with chains: http://traxxas.com/forums/showthread...33-tire-chains
    RACE IT, BREAK IT, FIX IT, REPEAT!
  40. #80
    Dec 2013
    87
    Quote Originally Posted by atclauss View Post
    i dont need chains there is no more ice. just wondering why other mamba monster slashes pop wheeies and mine doesn't.
    LEFT TURN ONLY
