    Jan 2008
    Cottage Grove, MN
    620
    Is it the Clutch Shoes?
    The other day my 3.3 Jato stopped moving but the engine rev'd fine when hitting the throttle. Today I took it out and I have to apply the brake or it will go full rev and take off. Does this sound like a clutch shoe issue? I just always thought if it was the clutch it wouldn't go anywhere (kind of like how it was behaving the other day) If so, what clutches is everyone running. Just Traxxas stock? Thanks!
    3.3 FOC How-To: http://tinyurl.com/557zsy
    Riverton Utah
    4,343
    Ya, having it stop moving sounds like the slipper clutch is too loose, and having it move at idle is a bad clutch. The best clutch IMO is the MIP clutch. It lasts longer than the stock clutch, and it has more "grip".
    http://www.rcplanet.com/Clutch_Kit_Jato_p/mip1620.htm
    Jan 2008
    Cottage Grove, MN
    620
    Thanks.. I will order up the MIP clutch!
    Tanker 822
    9,629
    Two things: if the truck will want to move when starting and will stall when you come to a stop then the clutch is bad. If the engine revs but the truck does not move (assuming the clutch bell and spur gear are spinning) then it is the slipper clutch.
    If it wants to rev up while sitting still, check your tune.
    Jan 2008
    Cottage Grove, MN
    620
    So I got the new MIP clutch today.. but I notice when I try and remove the nut on the spur gear\slipper the shaft just rotates (even when holding the spur gear with my hand) and the nut will not loosen.. trans issue?
    Jan 2008
    Cottage Grove, MN
    620
    NVM... I was able to get the nut off..
    Jan 2008
    Cottage Grove, MN
    620
    So I got the clutch bell off and the clutch and spring are intact.. hmm. I am going to replace the slipper clutch shoes..
