    Oct 2013
    194
    Shimming my rear and front differntial going wrong?
    Hi,
    I was shimming both my differential and it seems like now they are a bit stiff and clicking...
    I've done like Jimmie said in his shimming post...
    Start with 4, went to 3, then 2, then 1...
    2 was clicking a bit but 1 was made it spin free and in the article it said it needs just a bit of force to spin, which was suitable with 2 shims...
    Is it normal? or should I remove 1 shim from each?
    Thanks,
    Barak.
    Alma, MI
    12,279
    Brand new diff parts?
    Oct 2013
    194
    One was brand new, the other was the front diff which is like new..
    (As usual - thanks Jimmie. should had that to my signature lol)
    Alma, MI
    12,279
    With new diffs, a little on the tight side is OK as they will wear into one another.
    Oct 2013
    194
    Dropped to one shim and now it goes freely.
    So you say better get it tight so they will wear out into each other? Cause it sounded pretty bad..
    SE Texas
    1,179
    one shim should be fine...if it wears and starts clicking again...you can add another.
    "Dude,I almost had you"
    R.I.P Paul Walker
    Oct 2013
    194
    Ok thanks guys!
