Results 1 to 11 of 11
    Dec 2013
    14
    Traxxas 9.6v 5000mah Problem
    So I'm guessing I got a Bad one like everyone else...
    Got it Brand New the other day, put it on my EZ Peak, it Beeps when it's done, I put it in my Rustler VXL, Turn it on, give the Truck some Throttle to make sure it's Working and it is, get the Body Clipped on, by the time I get outta my House and Outside, the Truck will barely Move.
    So do I have a Bad one like everyone else?
    I even Discharged it on the EZ, and Recharged it and same thing.
    Measured the Voltage with a DMM and IIRC, it was 9.14v
    Alma, Michigan
    12,290
    Brand new pack?
    If so it could take a few cycles to liven it up... try researching "form charging" and following those instructions. If that doesn't work I'd call Traxxas to see if they will replace it. Or just start there if you want... lol
    Dec 2013
    14
    Ok, looked up Form Charging, and things are getting Confusing.
    This is what I came up with:
    5000mah 9.6v 8 Cell Battery
    Set EZ Peak Plus to Charge / Discharge 3 times
    Discharge at 2amps down to 7.2v
    Charge at 5amps
    EZ Peak Plus Clicks Off when it's done
    Does that sound Correct?
    Alma, Michigan
    12,290
    Sounds right from what I remember... haven't ran NiMH in forever. lol
    Dec 2013
    14
    Yea, I'm catching Crap from my Friends about it too.
    Just Ordered a few LIPO's before
    Alma, Michigan
    12,290
    It is a night and day difference between the two technologies, that is for sure.
    Dec 2013
    14
    Ok, just Finished the 3 Cycles, here's the Results:
    Charge 1 - 389mah
    Discharge 1 - 288mah
    Charge 2 - 768mah
    Discharge 2 - 552mah
    Charge 3 - 1315mah
    Discharge 3 - 996mah
    So, looks like things are getting better. I'm gonna keep Charging / Discharging and see where I end up after 3 again.
    How High should I get the mah before I try to see if it'll Hold a Full Charge?
    Alma, Michigan
    12,290
    See how it performs in the RC... it should keep improving with use and/or cycles though.
    Dec 2013
    14
    Yep, it's getting better.
    Unplugged it for the Night while I Sleep.
    I'll hit it Tomorrow with a Set of 5 Cycles and see how it goes.
    Charge 4 - 1925
    Discharge 4 - 1534
    Aug 2013
    24
    I have found that LOTS of people have the same problem (like me) and I do not recommend this
    ziggy ziggy coco pop ziggy ziggy pop!
    Jul 2007
    1,256
    Where did you buy it? Usually when I have an NiMh that does that it's because it's been sitting for a very long time.
    I need R/Cers anonymous.
