Results 1 to 7 of 7
    Russia Samara
    75
    Carburetor TRX vs Losi
    how different between carburetor from traxxas and losi? Both has plastic housing. May be recommended carburetor with metal housing?
    I like the technical beauty!
    4,351
    The reason the Losi carb is better because it has a bigger throat so it can let more air into the engine. I have on my Slayer and I love it, it worth getting.
    Russia Samara
    75
    Thanks. I will try Losi. How much reconstruction i need for stock engine?
    4,351
    It's a 90% direct fit, all you need to do is raise the throttle arm up with a few washers and that's it.
    Russia Samara
    75
    Can i use stock throttle arm ?
    4,351
    Yes, you can use the stock arm. Just make sure it doesn't bind on anything once you're done.
    Woodward, OK
    430
    One of mine had some cast flashing that I had to sand off, the other was a direct drop in. I have one on a bone stock 3.3, the other is on a highly modified 3.3. The modified 3.3 is absolute screamer. It is a good mod to do.
    T-maxx 3.3
    Rusty 2.5r
    Summit VXL
    Nitro 4-tec
