    Land o' flat.....Saskatoon, SK
    801
    Motor Shaft Replacement 3.2mm to 5mm
    Is it possible to swap the 3.2mm shaft for the 5mm shaft without any mods to the motor?
    Thanks for the help,
    Clay
    15,151
    Absolutely not. The rotor magnet is bonded to the shaft. However, you can look into a bore reducer if all you are looking to do is use 5mm bore pinions. If you are looking for a stronger shaft, the entire rotor needs to be replaced.
    This is for the Castle Creations 1415 motor:
    http://www3.towerhobbies.com/cgi-bin...FYQ7OgodqmoA6Q
    Alt-241 on the number pad =
    801
    So I couldn't buy a 5mm Motor Repair Kit and use it instead of a 3.2mm Motor Repair Kit?
    15,151
    Quote Originally Posted by summitbasher240 View Post
    Yes you can, and I linked it, but your first post asked about the shaft, not the entire rotor.
    801
    Sometimes I don't ask clear questions. And never get driving directions from me. LOL.
    Thank you for the help,
    ksb51rl.
    15,151
    Don't worry about it. Either way, we'll eventually get there.
