    Nov 2013
    Looking for a radio connector?
    I'm a noob, I hope this is ok to post here. I didn't see a more appropriate forum?
    My son has an HPI truck with a Traxxas XL5 ESC. He was screwing around with his wiring, and tried to cut a zip tie, and ended up cutting off the three wire radio connector . He snipped it too close to the connector, I can't splice it.
    I don't recognize just the plug as a commonly available electronic accessory, and I don't see it available in the Traxxas parts lists. Is there anywhere I can source another one? I'm considering posting up in the Marketplace to see if anyone has a burned up ESC I could buy for a couple bucks to scavenge the connector off of, but is the part available new anywhere?
    Sep 2012
    78
    Your lhs should sell extensions, y splitters, or just the connector you need. You could salvage from a broken servo if you have one. The pins are the same as usb or front panel (power switch, reset, led) connectors on a computer motherboard. If all else fails you could source pins from old/broken computer or cabling retailer, recrimp pins and reuse old plastic connector.
    Nov 2013
    Awesome, that's what I needed to know. Thanks very much!
    Alma, MI
    12,280
