    Oct 2013
    Norwalk, OH
    61
    QR-1 battery charging . . . pin size?
    I seem to be having problems when trying to charge my QR-1 batteries. It appears that the pins in the male plug (charger) are too small for the battery plug (female receptacle). I frequently have to wiggle the battery around just so in order for the charge LED to illuminate.
    Does anyone else have this problem?
    Jun 2013
    Ontario, Canada
    222
    I did, until I read somewhere on this forum that the male batt plug goes into the charger very securely, meaning you have to push it in forcefully until it almost clicks into place. Try it, it works!
    I had the same prob with what I thought was finicky plugs until I plugged them in correctly! Goes right in, light lights up!
    Aug 2012
    Middle, Georgia
    972
    I had the same problem. Then realized that you must push the battery plug into the charger port until it clicks. It should hold it very tightly.
    Sent from my SCH-I535
