Results 1 to 17 of 17
    61
    Blinking red and green
    Hey guys I have a stock brush less merv with two spc lipos running in parallel. I just charged my batteries and now my receiver is blinking red an green fast. The light on my vlx does not want to come on. The car is dead nothing happens. Can y'all tell me what seems to b the problem?
    Alma, Michigan
    12,291
    Try unplugging the steering servo.
    Also, are you sure you are using the parallel harness?
    The only reason I ask is that this has happend before where the poster thought it was parallel and it actually was a series harness.
    61
    Its a parallel connector Jimmie. I'll try what u mentioned about the steering servo. If the car comes back alive with the servo unplugged what seems to b the problem? Thanks Jimmie!
    Jul 2012
    Yakima, Washington
    1,435
    The stock servos have been known to mess up everything, so if it comes back to life you need a new or possibly a different servo.
    61
    Cool thanks Revo. What servo do y'all recommend?
    Alma, Michigan
    12,291
    Blue Bird 390... 98%+ drop in.
    HiTec 5085... needs different servo horn.
    Corona something or other... someone else will chime in I'm sure.
    Traxxas Employee
    Oct 2012
    Lewisville, TX
    30
    The issue comes from the servo shorting back into the receiver. I've had this issue before with my 1/16th Slash brushless. I just replaced it with another stock servo, made sure to center it out and stopped tightening it down when it caught, instead of when it stopped, and I've been running it for around a year now with no issue. Just a head's up on what I've done with the stock parts. Haven't tried going after-market on it yet, if this servo fails I might experiment with that.
    61
    Definitely a bad servo. Disconnected it and car came back life. No I have to search for new one. Thanks guys for all the info.
    61
    Where do yalls get your parts from?
    Alma, Michigan
    12,291
    Where ever I can find them cheapest... including shipping.
    What are you looking for? Most of the time a Google search of the part number brings up quite a few options.
    61
    Need a new servo and some aluminum shock bodies.
    Jul 2012
    Yakima, Washington
    1,435
    Hot racing shock bodies are a good upgrade I like them.
    Apr 2013
    18
    I had my esc on lipo mode and plugged 2 Nimh in series and turned it on. Forgot to take it off lipo and it was flashing unplugged the batts and only plugged one in and turned it on and it worked fine . Set the esc to non lipo and plugged 2 back in series and worked fine.
    Jul 2006
    Indonesia
    1,311
    Monster, I have the same problem... but now it is blinking red ( low power mode ) when using one battery ... and blinking red-green when using 2 ... this is giving headache... My first Emaxx... I had 3 Tmaxxes and a Revos... totally noob about electrics... HELP...!!!
    BTW, mine is totally stock brush waterproof emaxx, 3906... burnt my ESC and bought a new one from ebay... put it on... the truck running slow and won't wheelie... so I thought probably in training mode... and I try to program the ESC, thats when the trouble started..
    Thanks all in advance...
    Alma, Michigan
    12,291
    What RC is this for??
    Jul 2006
    Indonesia
    1,311
    ok, I should go to Emaxx forum...
    Alma, Michigan
    12,291
    The electronics are quite different, so the advice will be different.
    The EVX2 is designed to run off from twin battery packs... because of the way it is wired, if you do not have twin packs or a jumper it will not run. That is probably your first issue.
    Your second issue sounds like you are plugging in twin NiMH batteries in LiPo mode. Try following this video:
