    Sep 2013
    55
    what slipper clutch is good for a e revo
    What is a good slipper clutch is good for the e revo running in 6s the original from traxxas or the heavy duty ones from traxxas
    kansas
    7,862
    Have to use the HD with the alum pads, and properly broke in. Should be the pads that comes with a BL Revo.
    or upgrade to the Robinson Racing.
    Slipper Clutch Break In
    Post #283
    http://traxxas.com/forums/showthread...=1#post5388463
    Aug 2013
    921
    1. Robinson racing slipper is great.
    2. Hot racing double slipper with aluminum pads works good too.
    3. Tmaxx brake pad mod is a cheap option
    kansas
    7,862
    Sep 2013
    55
    What do you mean by breaking in? So I cant just install the HD version?
    Post #283
    kansas
    7,862
    Slipper Clutch Break-In
    The E-Revo Brushless Edition’s slipper clutch requires a break-in procedure
    to ensure consistent operation with the extremely high power output of
    the included Castle Creations Mamba Monster brushless motor system. The
    slipper clutch has been adjusted to the correct initial setting for break-in.
    Follow these steps to ensure maximum performance and life from your
    slipper clutch:
    1. Make your first runs with the model using the stock gearing and 6- or
    7-cell NiMH packs, or 2S LiPo packs.
    2. Drive normally. The slipper clutch should slip momentarily when
    accelerating aggressively on high-traction surfaces (you will hear a
    whirring sound when the slipper clutch allows the spur gear to slip).
    3. If excessive slippage is noticed (slipping that lasts for more than 3
    seconds under hard acceleration), or the slipper clutch slips anytime
    the throttle is applied at any lever, stop driving immediately. Let the
    slipper clutch cool for 10-15 minutes. When the clutch is cool, test-drive
    the vehicle again. If you still experience excessive slippage, allow the
    slipper to cool once more, then tighten the slipper nut turn (turn the
    nut clockwise) and repeat the break-in process. Do not adjust the slipper
    clutch before it has cooled.
    4. Continue to run the vehicle and monitor slipper clutch performance as
    noted above, and readjust if necessary. When the run is complete, the
    slipper should be fully broken in.
    After break-in, the slipper clutch is ready for any type of driving, with any
    batteries up to 6S Lipo. Set the slipper clutch so it only slips for a moment
    (if at all) under hard acceleration in high-traction conditions. If excessive
    slippage is noticed, stop driving immediately. Continuing to drive with a
    loose slipper will cause damage to the slipper unit. You must let the slipper
    cool down to ambient temperature before tightening the slipper nut and
    resuming driving.
    http://traxxas.com/sites/default/fil...KC1491-R00.pdf
    Aug 2013
    921
    I never had done any slipper break in,and never had any trouble with it. I just fully tighten the nut, and then go back 1/4 of a turn, that works for me, currently have two emaxx, one erevo with no issues. HD slipper is nothing else that just three aluminum pads. If your slipper is too loose you will hear a high pitch noise, and it will smoked out, also you will see poor acceleration.
    Aug 2013
    921
