    546
    miss matched batteries???
    I know I would need to charge them seperately... but how bout running them? In paralell, a 2s and a 3s all types of dif MAH ect. LOL will the ESC just regard them as a 2.5s? good idea? bad idea?
    wanna run my merv w a 2s and a 3s for stupipd fast
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,057
    Running a 2 cell and a 3 cell together is not a problem but running packs of different capacities (mah) is not a good idea.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Alma, MI
    12,279
    NEVER EVER run two different cell counts in parallel. The higher cell count pack would overcharge the lower cell count pack.
    Now, two different cell counts can be ran in series; but all other aspects of the pack need to be the same.... capacity, brand, age, C rating, ect.
    For charging, same cell count packs of different capacities can be charged together as long as they have a similar voltage across all packs. When I was running my Summit's 2 7600mAh 2S packs down along with my 16th Revo's 4 2200mAh 2S packs I would parallel charge them all at once.
    If charging different cell count packs together, series charging is the way to do that.
    More info:
    https://sites.google.com/site/tjingu...allel-charging
    https://sites.google.com/site/tjingu...erial-charging
    Aug 2007
    So Cal
    21,057
    MY BAD!!!! I read parallel but was thinking series.
    BlindMan Racing
    SPC Lipo Power
    Alma, MI
    12,279
    I figured... I re-read the original post and yours a few times just to make sure I wasn't missing something.
    We all make mistakes!
    Dec 2004
    3,642
    Quote Originally Posted by knall View Post
    My first thought is why????? If you want fast, just run a 3S pack.
    OK, something to think about; Ohm's Law says items connected in parallel have similar voltage across them but differing amps, while items connected in series have similar amps across them but differing voltage. So looking at the two packs you noted as items connected in parallel, they are by definition going to have the same voltage across them or at the very least - they are going to do all that is physically possible to have the same voltage across them. This means the 3S pack will dump everything it has across the connecting wire system as it tries to equalize voltage with the 2S pack.
    Do you see the problem with this now???? A 2S pack that potentially over-volts and a 3S packs that potentially under-volts, all happening at a very rapid pace. Best advice, don't try it!!!!
    546
    Yes I see the error in my logic now. Only reason I was thinking of doing it was because I had the 2 packs allready. I think I will stick w 1 3s for when I want a spectacular crash. LOL
