Results 1 to 11 of 11
    Oct 2013
    194
    HPI Sprint 2 Flux suspensions on a rally
    Hi,
    I'm about to convert my MERV to a rally and I need the shorter suspension...
    I found the HPI Sprint 2 Flux suspension (full set) for not too much and was wondering - will they fit? Are they any good? Better then the rally stock?
    Picture of them:
    Thanks,
    Barak.
    Alma, Michigan
    12,290
    Can you find some measurements on the shocks?
    If they are similar to these they will probably work with some modifications.
    Oct 2013
    194
    Their site is so unorganized it's amazing... I'lm still trying to find the specs on the net somewhere.
    Btw - how did you cut pillow towers?
    Alma, Michigan
    12,290
    With my finger nails.
    Just kidding
    A Dremel.
    Oct 2013
    194
    LOL! Nails are ok, just glad you didn't say teeth..
    I don't have those type of tools yet... Any way to avoid that?
    And the recommended length is 70mm?
    Alma, Michigan
    12,290
    It could probably be done with a hack saw and a file... but that kit has been discontinued.
    Did you know there is no difference in the actual shock in all the 16ths? To reduce droop Traxxas has installed a spacer within the shock of the Rally, Mustang, and possibly the Slash.
    Length of the stock shock from eyelet to eyelet in a Revo is 47.75mm
    Length of the stock shock from eyelet to eyelet in a Mustang is 43.75mm
    Oct 2013
    194
    Yep, i've read that while searching google for the difference, but I couldn't find that spacer...
    I was looking at these :
    http://www.ebay.com/itm/380695061897...84.m1438.l2649
    they have 60 / 55 / 50mm. but again, that **** with shortening the pillow towers is annoying... why can't I screw them like the traxxas suspension?! argh...
    Alma, Michigan
    12,290
    The Traxxas top cap eyelet is smaller than most others... meaning that others will not fit in the stock shock mount. It may be possible to put something like a hollow ball in the aftermarket top cap and then set it on a stack of properly sized washers to get the shock spring to chassis clearance.
    Oct 2013
    194
    Any chance you can upload a closer picture (side and above) of the way the shocks are installed?
    Alma, Michigan
    12,290
    I no longer have the RC's those were installed on... but you can probably get some close up pictures from the current owner: http://traxxas.com/forums/member.php?70842-graham_h
    Oct 2013
    194
    Thanks bro, I'll contact him.
