    Oct 2013
    Question Trying to figure out the axle carriers.
    I'm a new erbe owner (6 days). I'm trying to figure things out one small step at a time. I was wondering if someone could offer some insight on the assembly of the axle carriers, especially the pivot ball caps. I see how the special tool included with the erbe is used on this part, but I'm not sure what's happening when I turn it. Does it tighten and loosen the axle carrier's grip on the pivot ball? If it's loosened all the way, can the pivot ball be separated from the axle carrier? Any info would be helpful. Thanks!
    kansas
    7,844
    knuckles
    376
    http://traxxas.com/forums/showthread...=1#post5570206
    258
    http://traxxas.com/forums/showthread...=1#post5359224
    Well inset the pivot ball in the knuckle then screw on the cap, do not over tighten or it will bind the steering and the suspension. So leave just a little play, between the ball & the cap.
    Hint tighten the cap all the way down (no play) then back it out until it has a little free play..
    Oct 2013
    Thanks for the great info!
    kansas
    7,844
    sure... hope you were able to get what I was trying to tell you..
