    Oct 2013
    18
    Mamba monster esc problem
    Hi. I got my erevo used from a local guy. It was running good today. I just opened up the esc and blow out some dust inside, i put everything back, hook up lipo, turn the esc power switch on, and nothing is responding. I checked everything and i didnt do anything wrong, lipo is fully charged, i connected the esc to 2nd channel on the receiver, and i connected the 2200kv motor with it....I tried to do all i could to get the esc back working but seem like i couldn't...Oh, there was one time, the esc worked again, but only for few mins, it suddently stopped working while i was putting other stuff back on the car, it's like dead now...PLEASE HELP
    kansas
    7,812
    might be the on/off switch.
    bypass the switch
    cut the switch off & wire the two wires together. Should fix the prob...maybe...
    and welcome to the forums
    Oct 2013
    18
    bypass the switch
    Thank you so much. I cut off the switch, wired the 2 wires of the switch together, now it works....Not sure if it will cut off again like last time or not though, BUT IT WORKS AGAIN NOW. THANKS
    The Netherlands
    851
    Yep, I also had a dead switch a while ago, check my post in my thread:
    http://traxxas.com/forums/showthread...=1#post5524261
    It kept working fine after I replaced the switch.
