Results 1 to 12 of 12
    Jun 2013
    135
    Fix one thing, break something else
    Well I'm not sure what I've broken now or what is about to break. I was bashing this morning and now when release the trigger the wheel lock up. It doesn't do it every time but more often then not. Any ideas ?
    South Jersey
    696
    Tight pinion to spur mesh
    Anza Slash & a pile of Parts
    N. Idaho... Da Sticks!
    3,309
    Wheel, or wheels?
    If it is just one wheel, it is either something stuck in the drive shaft, or a bad bearing on that side.
    Both wheels, might be a bad bearing in the tranny.
    Constant beakage...
    Sometimes things just roll that was, it gets very frustrating, you usually work your way out of this cycle.
    Jun 2013
    135
    Yeah both wheels lock up. I hope it's not the tranny bearings, they aren't more than a week old.
    Michigan
    5,061
    Quote Originally Posted by Drew_1295 View Post
    Does it still go forward with out issue?
    If so perhaps your neutral setting is off.
    Jun 2013
    135
    Yeah it rolls forward fine when I pull the trigger. Just when i let off it stops. I've checked the pinion/ spur mesh and it's good
    Riverton Utah
    4,352
    I would reset your esc, and transmitter, it sounds like your Slash is hitting the brakes.
    Michigan
    5,061
    +1^^Yes it does.
    3,309
    After this, I would back the motor off, and roll the drive train by hand. See if you can spin the back tires, there should be a little bit of resistance, but they should be smooth and coast for a few revolutions. Also, spin the motor, you should feel some cogging, but it should spin freely.
    Jun 2013
    135
    Well I finally got around to taking my slash apart and do some diagnosing. Come to find out not only did I strip the spur gear I also had a blown bearing in the motor. The bearing that let go is on the closed end of the can. What is the best way to get this thing out?
    Oct 2013
    connecticut
    33
    There is a good vid on youtube how to rebuild the motor
    it wont let me post a list of my trucks here....
    Jun 2013
    135
    Yeah I have watched the video. It doesn't show how to remove a blown bearing though. The tire wrench doesn't work to remove the bearing now
