Results 1 to 13 of 13
Thread: Motor Bearings
    Jun 2011
    Fredericksburg, VA
    301
    Motor Bearings
    The bearings in the back of my 1800kv Castle motor (stock) have started to fail . The measurements are 15x5x5mm. Does anyone know of replacement bearings for that motor. Castle would probrably replace it but I would like to upgrade the bearings. I also dont have the desire to wait 3-5 weeks without running my boat . Any ideas?
    Powered by Castle.....
    Sep 2010
    475
    The bearings are actually 5id x 14od x 5wide.
    You need something that can withstand high RPM and high temps.
    Jun 2011
    Fredericksburg, VA
    301
    Yes do you have any suggestions?
    Jul 2013
    580
    I would checkout bocabearings, they are ceramic which I don't know if that's good or bad but have heard good things about them in land vehicles. Not all bocabearings maybe ceramic but I know there is an option or something.
    PM for info.....
    Apr 2013
    368
    I got ceramics from boca. I cant get the bearing out of the back of the motor though. Castle says its been machined pressed in
    Feb 2013
    Ukraine
    17
    I install Avid ceramic bearings 5*14*5 http://www.avidrc.com/product/1/bear...-bearings.html
    It's easy to change them, you just have to heat the bearing and they fall off of the motor cover
    sorry for my poor english
    https://www.youtube.com/user/TheGuessua
    Jun 2011
    Fredericksburg, VA
    301
    Well my boat was making a funny sound. I brought it back to shore and the driveline was seized. Opened the motor and out fell bits of bearing guess I will be getting some new bearings!
    Jun 2011
    Fredericksburg, VA
    301
    Which bearings are you using?
    30
    Quote Originally Posted by PowerDemon View Post
    I'm guessing you will need a new motor. The same thing happened to me, and the magnets sucked all the debris into the core of the motor and took out the armature.
    Carmen
    PA
    226
    Bocas are excellent. If you order from them I highly recommend getting a thrust bearing to protect the rear bearing from failing again.
    Can't remember the exact size, the id just has to be 5mm or larger to go over the shaft. I had some tamiya bushings I used as spacers.
    Jun 2011
    Fredericksburg, VA
    301
    Quote Originally Posted by Redfire427 View Post
    Carmen
    Ahh I was hoping that I could get away with just a new bearing. I guess not....
    Jul 2013
    580
    Scaring me for when this happens to mine...
    PM for info.....
    Jun 2011
    Fredericksburg, VA
    301
    Quote Originally Posted by guessua View Post
    This is on the Castle Creations 1800kv motor right? I am about to order some.
