Results 1 to 21 of 21
Thread: Cooling upgrade
    Jun 2013
    SW Ohio
    25
    Cooling upgrade
    After a high speed collision with the shore I bought a new hull and decided to go with blue. I also added cooling upgrades from OSE (Dual pickup rudder, aluminum cooling jacket, dual water outlet). Haven't had it on the pond yet, hopefully tomorrow.
    Added the splash guard too.
    OSE trim tabs are next.
    Jul 2013
    587
    Very nice, looks very close to mine! Let us know hoe those OSE trim tabs work out! I have looked at these and highly considering them since no mods are needed...
    http://shop.rcboatbitz.com.au/index....oducts_id=1688
    Jun 2011
    Fredericksburg, VA
    234
    They look great! The only problem is that they ship from Australia. Thats a long ship to the US.
    Powered by Castle.....
    Jul 2013
    587
    Yep, I reallylike the look of them vs. the OSE tabs. Guess It would be winter upgrade! They have a few more toys for the Spartan so I guess it would be a $150---+ order!
    Jun 2011
    Fredericksburg, VA
    234
    Thats what I am thinking. I want the dual pick up rudder, trim tabs, and the strut. The total is about $150.
    Jun 2013
    SW Ohio
    25
    I'll keep you posted on them. As cool as the ones look that you posted I'm going to stick with OSE. He's in the states and ships FAST.
    Jul 2013
    587
    Thanks FearSys, I prefer to order from the U.S, but I have been to Australia so was thinking about giving boat blitz a shot for my orders. It looks as they have some very good products, the only issue would be waiting. I just email OSE on their CNC trim tabs to see how long they are, I asked them before but never got a straight answer. Just curoius, has anyone wired 4 lipos together? Assuming that the owner has 4 5000mah packs @11.1VTS, then if wired they could have a total of 10,000MAH on each side. Just some thinking while sitting at the dinner table! Maybe something like this but with LARGE cabling and connectors??? This means in my thoughts that I could have 22.2VTS and 20,000mah total!!!!
    I think it's a parallel Y harness for the 1/16 line, in theory it could work? Don't mean to try and change the thread topic....
    Sep 2010
    384
    The 1/16 adaptor would never handle the current the Spartan power system pulls. You would need to remake it with loose connectors and at least the 13ga wire that comes stock on the Spartan ESC. I would say 12ga is better.
    That being said, if you put 4x 5000mah 11.1v packs in the boat the weight would be tremendous. I would be concerned about overheating the system due to the difficulty of pulling so much extra weight around coupled with the longer runtime. Run one pair of batteries, swap, then run the others with a cool down period in between. The most we suggest running at one time are two 8400mah 11.1v packs.
    El Cajon Ca
    1,781
    Quote Originally Posted by Spartanator View Post
    They say that the strut is 10mm longer and will require the use of a longer flex shaft or wire drive depending on what you use. Also, they have bushings in the strut instead of bearings..... Just some food for thought..... It's only $$$$
    "enjoy your ride"
    Dennis
    Jul 2013
    587
    Quote Originally Posted by TireSlinger View Post
    I know the adapter couldnt handle the power but was just curious if it would work, yes the weight would turn flex cables into twizzlers. I use to run the 8400mah @ 7.4 but no longer have those lipos. I destroyed a flex cable on 4s with a bag of ice(to help cooling, which it did not due to extra weight). I wish SPC made batts with more mah!
    Jun 2011
    Fredericksburg, VA
    234
    Quote Originally Posted by orca44 View Post
    The flex I have is long enough for that strut. I think it would help with precision tuning. The only problem is that I have to drill two extra holes in the transom. I am not too keen on that idea.
    Jul 2013
    587
    That's why I'm sticking with the stock struts... I don't need a Swiss cheese boat! I most drilling I have done is for secondary water outlet and splashguard. It does look cool though!
    PM for info.....
    Mar 2013
    363
    they do make 8200 mah 2s batts that i own 4 of and they work perfect.i also just got their 6500 mah 3s batts but i only have 1 run on but they worked great
    El Cajon Ca
    1,781
    Quote Originally Posted by PowerDemon View Post
    I use that style of strut on one of my none Traxxas fiberglass V hulls and it works very well for adjusting strut angle in very small increments and stays put...
    As far as adding two more holes in your hull to mount the strut.... If you seal the screws that will be added with a marine silicone sealant, You should not experience any issues.
    "enjoy your ride"
    Dennis
    Jun 2011
    Fredericksburg, VA
    234
    Do you use the Speedmaster one?
    Jul 2013
    587
    Quote Originally Posted by hopduperevo View Post
    Thanks, I had a pair of 2S 8400 packs but they were not SPC, that's why it was easy to let them go. I have never ordered batteries from SPC, as many great things I have heard I imagine that a pair of the 6500's from SPC would satisfy my Spartan. I would get M_XAMPS but they are more than I payed for my Spartan!
    El Cajon Ca
    1,781
    This is the one I am using on my other V hull...... I don't remember who it is made by.
    "enjoy your ride"
    Dennis
    Jun 2011
    Fredericksburg, VA
    234
    Ok thanks. It seems to resemble the one from rc boat bitz. It looks a little shorter though. Have you received good results with this strut?
    El Cajon Ca
    1,781
    It is shorter than the one from rc boat blitz.
    The one I have on my other V hull has been in use for a little over 2 years and has served me well. I like the fact that it stays adjusted in place.
    "enjoy your ride"
    Dennis
    Apr 2013
    360
    Howd you install the water blocking thing in the back?
    El Cajon Ca
    1,781
    What water blocking thing are referring to?
    "enjoy your ride"
    Dennis
