    Aug 2008
    sunshine coast queensland
    20
    Unhappy Slow 3908 PLS Help
    Hello all i am running a stock 3908 with 20/68 gearing with . . . 5000 mah 2 s lipos and my top speed is 24.8 Mph using a garmin etrex 10 gps for speed checking , the traxxas site says i should be getting 40 + mph this is way off any help would be greatly appreciated i also have full telemetry setup but cannot figure out the final drive ratio!
    Edited for language abuse. If you see a starred out word in your post, you must edit it out to avoid earning warning points; this also applies when a company or product name has been blocked by the filter.
    Aug 2013
    Ont, Canada
    79
    I assume you are running on a hard surface? Try the optional 62 tooth spur gear....just check the temps to make sure things don't heat up too much.
    muscoda, wi
    1,245
    watching temps of course. I run 20/54 all the time.
    Brookline, NH
    1,206
    Have you checked to see if the esc is set for 100% forward speed? Also if you have the telemetry and ipod check to see that it isn't set to training mode? Just a thought.
