Results 1 to 18 of 18
    1,473
    Castle 1415 2400KV Gearing Question
    What gearing and Lipo do you-all run with the 2400KV?
    What temps do you get on the motor?
    I run 17/54 on 3s and have the feeling motor temps to be little on the warm side like 150F?
    I don't know if i am under- or overgeared. ESC temps are very low and i run mostly around half throttle.
    Since i run in a rather small bashing spot with some jumps and U-Turns there is a lot of stop and goes too.
    THX!
    EDIT: Top Speed calculator says 48 mph - pretty fast
    1,473
    Ok so today i got 158F max. / Outside Temps: 60F
    So this is a little to high to my mind.
    ESC Temps: 113F
    Wales in the UK
    4,944
    The motor temps are fine as long as they don't go over 180f and the esc over 150f.So you are all good dude......peace
    1,473
    Thanks!
    So i decided to try a 14T pinion instead of the 17T since i want to run the motor as cool as possible
    I had to dremel a little bit more off the chassis to make the motor sit perfectly, but was pretty straight forward.
    Also i set punch control on the WP-SC8 from 5 to 3, since it got even more torque with the smaller pinion.
    If the weather stays like this i'll try that setup tomorrow.
    Wales in the UK
    4,944
    I hope its dry tomorrow too because I love my new 3s pack it makes my pede go crazy man.And my new settings are punch 5 with the revo slipper set at 3/4 turn from tight and you are right its very hard to get my truck up to full speed running 15t pinion with a 3500kv 4 pole so one day I may try 13t pinion and 52t spur for more torque and acceleration .......peace
    1,473
    Nice! Today i ran with the 17T / 3s and the Pede is much too fast. Speed calculator says over 46 mph.
    With 15T I still get about 40 mph top speed which is more than enough
    Wales in the UK
    4,944
    Mine on 3s is around 60mph which is crazy fast that's why I changed down from the 17t pinion to 15t but its still a bit to fast because speed runs get boring quick and speed runs with a monster truck is like taking a supercar to a short course track.....peace
    1,473
    Yeah i am not a big fan of speed runs. They get boring pretty quickly. I did those speed runs back in the days with my mini e-revo on 3s.
    1,473
    Great weather today and time for another test session:
    With 14T Pinion and Punch Set to 3 the Motor Temps today were 137F but still more than enough power and top speed with a 3s pack.
    Also the Stampede was much more easy to control and throttle was not so sensitive anymore.
    Just found my personal sweet spot with this motor and setup.
    perfect - love it !!!
    1,473
    One thing i noticed is that the Low Voltage Detection of the WP-SC8 kicks in little to early. At the end of the run i still got 3.69V / Cell. Think i will set it from 3.4 to 3.2 (default) again.
    Nashville, TN
    1,743
    The LVC is kicking in because, under a load, the lipo voltage is dropping below 3.4v/cell. It'll always be a little higher once you pull it out and check it.
    Wales in the UK
    4,944
    Just make sure the cells never go under 3.0v or you will wreck the lipo dude.......peace
    1,473
    I set it to 3.2V today and got 3.5V after the run. As soon as i arrive at home i recharge to 3.8V.
    Wales in the UK
    4,944
    Good man and I am stoked that you are loving the new motor........peace
    1,473
    Yeah it's awesome. So much power available. I did some crazy high jumps and back flips at my BMX track today. So much fun!
    Wales in the UK
    4,944
    I have been trying double backflips up the park and have landed a few which feels awesome but I think I could maybe land a triple.........peace
    1,473
    Nice!!!! I am still working on my single With my mini e-revo i could also do front flips. don't know if the stampede can do them too. I just hit the brakes in the air as hard as possible and the mini revo would front flip
    Wales in the UK
    4,944
    Yeah I got front flips dialled in already man I just love bashing and jumps....peace
