    Mar 2013
    Clitherall MN 56524
    75
    Traxxas TQI 2.4 radio setup
    Is there a way to reverse only 1 steering channel?
    I am running this radio in a Tamiya Clod and need 1 Ch.1 reversed - I tried switching the plugs around but it senses that and shuts both Ch.1's down all together..
    Any help would be great..
    EDIT -I have the TRX link version that can use a Ipod or Iphone.. I do not have either..
    Alma, MI
    12,280
    No there is not... both channel 1's are ran in parallel on the Rx. Also, flipping around the connector only takes the servo ground to Rx signal and servo signal to Rx ground.
    A signal reverser might work...
    Mar 2013
    Clitherall MN 56524
    75
    I see I was able to swap the rear steer servo saver to fix the issue
    NOW ON to the next issue I am having trouble reprogramming the multifunction knob to the throttle sensitivity - I tried like 4 times and it always goes to the steering sensitivity..
    Oct 2013
    Polk,NE
    133
    I have 2 steering servos on my merv with the TQi transmitter and the second servo is reversed when I have both plugged it
    Alma, MI
    12,280
    Are both servos the same?
    Oct 2013
    Polk,NE
    133
    On my merv, they are both trx2080
    Alma, MI
    12,280
    Something isn't right... it is impossible for one to receive a different signal than the other. Are you sure they are moving in opposite directions?
    Oct 2013
    Polk,NE
    133
    I was looking at it wrong. I apologize
    Alma, MI
    12,280
    No problem!
