    Jun 2013
    Monterrey
    4
    Opening carburator should be equal to displacement of the trigger in the transmitter
    I'm new to nitro rc carr, my question is, if the displacement of the trigger must equal the carburator, why minimally touch of the trigger opens the carburator all.
    I tried to adjust throttle rod and trigger sensitivity but failed to trigger displacement is equal to the carburator,or that it is.
    My car is Jato 3.3
    Gurley, Alabama
    750
    If the carburetor slide opens and closes all the way everything is working fine.
    Oct 2013
    6
    If the carb is opening all the way with little trigger movement, try replacing receiver batteries.
    Tanker 822
    9,404
    Everything may be working fine. You may want to check what hole the linkage is attached to on the servo horn.
    Sep 2010
    384
    The Jato requires a fairly short travel of the servo arm to achieve full throttle. You may need to adjust the endpoint of the throttle channel lower so when the trigger is fully pulled the carb has just hit wide open.
