Thread: lipo balancing
    Aug 2009
    83
    lipo balancing
    just started using lipo batterys ive charged mine prob 2-3 times balancing every time and when done i check the balance its been 4.20 except this time it was 4.20 and 4.16 is this bad or is that close enough
    Alma, MI
    12,281
    They should be closer than that... either the charger timed out, reached capacity cut-off, isn't balancing the pack properly, or the pack has something wrong with it.
    Which batteries are you using?
    What RC are they in?
    What charger is it?
    Aug 2009
    83
    using venom 2s 5000 mah and a venom pro 2 charger charging at 5 amps in balance mode running in a slash 4x4
    15,577
    What charger is it?
    Yup. Or the charger voltage sensor has a fault. (Least likely of the possibilities.)
    Alt-248 on the number pad =
    Aug 2009
    83
    i hope not the chargers brand new 2nd one i owned first one i plugged in the wall and it blew up instantly
    15,577
    Quote Originally Posted by zx809 View Post
    And you bought (or accepted) a replacement...
    Good thing about Venom electronics and electrics: they have a very liberal replacement policy.
    Bad thing about Venom electronics and electrics: you'll need to use the liberal replacement policy.
    Oct 2010
    NJ
    777
    ^^ lol. You just can't go cheap on batteries and chargers.
    Aug 2009
    83
    there trying to tell me the battery is no good? i think its the charger
    it did say bad connection when i first plugged it in
    Alma, MI
    12,281
    It could be either.
    It could be that the balance connector is dirty.
