Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 493
  1. #121
    Sep 2013
    Maysville,Ky. USA
    431
    Hoped to see a broken axle shaft just nothing major . Maybe once i get the super swampers mounted i will have better luck. I have a quick question for the guys that run a Mamba 2200 or a brushless motor close to it. What kind of gearing are you running with your setup and what gearing would you suggest i try next?
  2. #122
    Sep 2013
    Maysville,Ky. USA
    431
    Ok its not broken but its hurt. The bearing for the pinion gear in the rear end my have went bad. I will have to take a closer look tomorrow when i am off work. If i hold the front wheels and turn both rear wheels at the same time there is a loud popping noise. It sound like the ring and pinion gear are slipping but it doesn't happen in just on spot as if a tooth was broken off. I'm not usually a basher more of a trail guy myself just testing it hard to see if there is something else that need improved on.
  3. #123
    PM me if ya wanna bash at Greenwood Bashplex!
    12,961
    Hope you dont find corn flakes in the diff area... That motor scares me lol...
  4. #124
    Sep 2013
    Maysville,Ky. USA
    431
    But it's a blast to drive. At first the noise sounded like the spur gear was getting eaten alive . Hopping for bad bearings or maybe bolts in the bulk head came loose allowing the pinion shaft to move side to side. No cornflakes no cornflakes!!!
  5. #125
    Sep 2013
    Maysville,Ky. USA
    431
    Ok couldn't wait until tomorrow . The inner bearing on the pinion gear was gone as in nothing left but the inner race that was seized to the pinion gear and the outer race . On the up side the entire diff was full of some pretty glitter. No broken teeth but they are now about 1mm shorter . Pretty sure its just gonna be cheaper to but a whole new diff and would be a good time to put in those aluminum diff cups from Leading Edge Machining.
  6. #126
    Sep 2013
    Maysville,Ky. USA
    431
    No one has had the beadlocks in stock and i had so time on my hands while i wait for my new diff to arrive. Only had enough rims to mount 1 tire for now but have 6 more rims on their way . No going to glue them just in case RC4WD gets the beadlocks in and they fit really tight so i shouldn't have any problems. Was just messing around when i made this one so when the others come in i will post some pics of how i made them fit if anyone wants to try it out.[IMG][/IMG][IMG][/IMG]Just a hair bigger then stock wouldn't you say?
  7. #127
    Jul 2012
    Yakima, Washington
    1,420
    Wow those are some tires.
  8. #128
    Lehi, Utah
    1,322
    This built is AWESOME!! Very great job. Truck sounds like an absolute BEAST.
    Those tires are HUGE. Those will get ya some good clearance.
    Slash 4x4 built from Proline RPM STRC TRX and MIP
  9. #129
    Mar 2013
    Calgary, Alberta, Canada
    45
    Sorry this is a bit late, but there is a guy on youtube that makes some pretty sweet servo winches and sells them through a website. his channel name is Knoxmotorsports (on youtube), not to sure the name of the website, but pretty sure you could google it. the servo winch he sells is strong enough to pick up a 2or3 ton floor jack.
    My name is Mud!!
    Summit LT
  10. #130
    1,161
    Gezz from the side they looked like the mud slinger. You are going to have to glue em. I tried running the singers without glue on stock rims and they walked right out if the rim in less than 5 feet.
    Sent from my SGH-I337M using Tapatalk
  11. #131
    Oct 2013
    Polk,NE
    133
    I put the axial 3.8 beadlocks on my revo-e conversion and love them. The hold up well, and will work with square beads and traxxas beads. I wouldn't get the chrome ones again without putting clear coat or clear nail polish where the wheel nut goes on. Even with the washers that come with, the chrome pealed at the center
    KCCO
  12. #132
    Sep 2013
    Maysville,Ky. USA
    431
    Quote Originally Posted by Bash'n'slash View Post
    Thanks always good to hear.
  13. #133
    Sep 2013
    Maysville,Ky. USA
    431
    Quote Originally Posted by MudMisfit View Post
    tried making my own but only had the stock Traxxas servo on hand. I will check this one out it sounds like what I am looking for. Thanks for the help.
  14. #134
    Mar 2013
    Bellevue, NE
    102
    This is one redic build, can't wait to see all those tires on the truck. Keep up the great work.
    1/10 Summit & 1/10 E-Slayer
  15. #135
    Sep 2013
    Maysville,Ky. USA
    431
    Forgot to upload a pic from the front .[IMG][/IMG]
  16. #136
    Mar 2013
    45
    That's a Monster!! (Will be). Nice work! I'm used to my summit LT with 2.2's, and it's crazy seeing them next to the stock summit tires, but that thing....Wow. I can't wait to see that massive beast when it's done!!
    My name is Mud!!
    Summit LT
  17. #137
    Sep 2013
    Maysville,Ky. USA
    431
    Thanks for the great words of encouragement . I really dig that GMC LT Summit you built as well . Those tires look awesome and the under glow lights make it look mean . All you need now is some black smoke rolling from those stacks.
  18. #138
    Sep 2013
    Maysville,Ky. USA
    431
    Quote Originally Posted by Crock View Post
    I thought it over and it looks like i might as well glue the wheels . The Summit is starting to get fat to the point that it needs to go on a diet. Just the rubber itself weigh around 3 pounds so if i keep the stock plastic wheels it should save me 4lbs .
  19. #139
    Sep 2013
    Maysville,Ky. USA
    431
    Installed the new rear diff just leaving it stock until i can order the entire set of hardened gears from Truckmonster. I stopped at LHS and picked up a 65 tooth spur . Had to move the esc over just a little so the motor would lay over enough for the gears to mesh. A 65 tooth is as small as i can go until i get a larger pinion. I also move the pushrods all the way in so that it would jack the chassis up for the front tires to clear the new body when steering.
  20. #140
    Sep 2013
    Maysville,Ky. USA
    431
    Rims are about 80 miles away right now so should be here in the morning . Taking it out now with my son's Rustler to see which one is faster. Might have to let out on the throttle just so he can win.
  21. #141
    Sep 2009
    Victoria B.C Canada
    5,078
    Jacking it up is hard on the cv joints
    Wears them quicker.and with the amount of power you have it's going to make them cry. lol
    Sent using lipo power
    Mountains cant stop me
    they have tried
  22. #142
    Sep 2013
    Maysville,Ky. USA
    431
    When i get the big tires mounted i'm gonna set the punch control at 50% to give the parts a rest . I have the field programmer so when i want to bash it a little its quick and easy to get the power back. Jacking it up is the easiest way to fit the F150 body . I think the body will be well worth some worn parts when done . My younger son would be upset if i don't use the body since it came off his toy rc and he thought it would look cool on daddy's Summit or as he calls it the (Fordit). We are both big Ford fans.
  23. #143
    Sep 2009
    Victoria B.C Canada
    5,078
    Not saying don't do it
    Just warning you to get a couple spares so the fun doesn't end to quickly.
    they have tried
  24. #144
    Sep 2013
    Maysville,Ky. USA
    431
    Not a problem was thinking it might be easier to pick up a cheap roller on eBay for spare parts.
  25. #145
    Newcastle, Australia
    951
    Quote Originally Posted by malonefamily2003 View Post
    That would be a good idea. Disassemble it and put it in a tool box to carry with you.
  26. #146
    Sep 2013
    Maysville,Ky. USA
    431
    Just wondering if anyone has seen a Summit do a standing back flip or if it would be possible without destroying it ?
  27. #147
    1,161
    yep all kinds on the u tube
  28. #148
    1,543
    Not the best idea for the diffs and drive shafts
  29. #149
    Sep 2013
    Maysville,Ky. USA
    431
    Quote Originally Posted by soundmaster View Post
    I knew someone was gonna say that. I Better wait for some more upgraded parts first.
  30. #150
    Jan 2014
    11
    I had a savage flux hp for a while before my summit and that thing is advertised to do standing back flips. Double flips if your using 6s. Initially I ran it on 6s and it broke all the time. Switched to 4s and could still do flips but I avoided it because it would still break stuff. I even stopped doing block long wheelies with it because it was blowing my front diff. That thing was such a PIA to work on I became scared to do anything that it was supposedly meant to do. I can't imagine the summit handling it well especially the way yours is set up no matter what upgraded parts you put on it. However, doing insane stuff and fixing the broken parts is the best part for a lot of people. If the savage was easier to work on I wouldn't have minded so much.
  31. #151
    Alma, MI
    12,280
    I did standing back flips all summer with my MT4... it is about the same size as a stock Summit, just a bit lighter with a entirely different balance and build. I am surprised it held up to the abuse... until fall. Then I split the rear differential cup... so, if it is possible to get that RC built up to withstand constant abuse, the Summit should be able to withstand the abuse some of the time I would think. The Summit does have more parts though... and yours has absolutely monstrous tires; that is a lot of weight to get moving all at once. Those are my only concerns as to the possibility of completing such a feat and the Summit taking it in stride.
  32. #152
    Sep 2013
    Maysville,Ky. USA
    431
    Quote Originally Posted by cottoneyed joe View Post
    I started to get the Savage but then saw the Summit and had to have it instead. So glad i did its a ball of fun to work on and just as fun to drive .
  33. #153
    Sep 2013
    Maysville,Ky. USA
    431
    I just put the Summit on the bathroom scales this fat cat weighs it at 29lb. Dont think it will ever see a back flip .
  34. #154
    Sep 2013
    Maysville,Ky. USA
    431
    SUMMIT OVERKILL[IMG][/IMG][IMG][/IMG][IMG][/IMG]
  35. #155
    1,543
    Those Tires are huuuuuuuuge!
  36. #156
    Oct 2013
    Finksburg MD
    149
    Wow! What a monster,Those wheels are huge.may I ask what's the weight per wheel with rim?
  37. #157
    Jan 2014
    11
    Holy crap that thing is gonna be awesome in deep snow and mud.
  38. #158
    Alma, MI
    12,280
    Someday... just maybe... I'll have those wheels with the proper upgrades to handle the stress.
  39. #159
    Sep 2013
    Maysville,Ky. USA
    431
    Quote Originally Posted by Cky View Post
    Tires weigh 41.9 oz plus whatever 2 stock rims and a small amount of epoxy. So right at 3lb each.
  40. #160
    Sep 2013
    Maysville,Ky. USA
    431
    I will be one step closer when LEM releases those beautiful axle shafts and other goodies they are working on.
