Page 11 of 15 FirstFirst ... 910111213 ... LastLast
Results 401 to 440 of 561
  1. #401
    Newcastle, Australia
    965
    Quote Originally Posted by malonefamily2003 View Post
    Would it be possible to run a cheap secondary esc and a small 380 motor off the stock Traxxas remote using the 3 position switch . I don't unlock the diffs so I could unhook them all I use is high and low.
    What would the secondary motor and ESC be used for?
  2. #402
    Princeville, Québec
    932
    i don't think it is possible. The 3position swich works with ch4 & ch5. those two channels are sending different signal through differents wires. so the ESC wouldn't receive the signal from one or the other channel.
    Summit RX8/1550kv-Slash4x4 MM2/2400kv Twin-V Merv.
  3. #403
    Sep 2013
    Maysville,Ky. USA
    602
    Quote Originally Posted by JoelRobbo View Post
    Just wanting to put some extra weight on the front..
    Like a super heavy duty winch .
  4. #404
    1,172
    You could probably do it with a old school speed control.
    Sent from my SGH-I337M using Tapatalk
  5. #405
    Sep 2013
    Maysville,Ky. USA
    602
    Quote Originally Posted by Crock View Post
    You mean like the mechanical kind .
  6. #406
  7. #407
    Alma, Michigan
    12,290
    It may, but still not on channels 4 or 5... the only other channel it might work on is channel 3; and even then the thumb switch would need to be modified to have 3 positions.
  8. #408
    1,172
    ya something like this.
    http://www.ebay.com/itm/Traxxas-2818...item51ba673d49
    using the locker control switch and a micro servo you should be able to set it up so you have forward and reverse
  9. #409
    Alma, Michigan
    12,290
    Forward and reverse... but no neutral.
  10. #410
    1,172
    The top switch has 3 positions. With the mechanical controller you could just move one of the wires to a different spot so your neutral would line up with the switch
  11. #411
    Alma, Michigan
    12,290
    Yes, it does have three positions... over two separate channels. There is no way to have a center in either channels 4 or 5. Channels 4 and 5 are half channels.
  12. #412
    1,172
    Still doable. 2 feeds to one servo.. add a resistor or something inline so voltage only goes one way (would have to look it up been a while since i played with electronics) and does not feed back to rx.
  13. #413
    Sep 2013
    Maysville,Ky. USA
    602
    Haven't opened the Tx yet but hoping maybe I can just add some small springs under the red hi/low toggle switch so that it balances in neutral. I have several drill motors I can use instead of buying a new 380 .
  14. #414
    Alma, Michigan
    12,290
    It will take some digging, but there is a step by step how to in the radio section on how to mod the switch to function as a 3 channel.
  15. #415
    Princeville, Québec
    932
    It would still be easier and less expensive to get a hacked GT3B/8channels combo to do what you want to do. My 2 cents!
  16. #416
    Alma, Michigan
    12,290
    I second that!
  17. #417
    Sep 2013
    Maysville,Ky. USA
    602
    What kinda money would one run ready to roll for Tx and 8 ch didn't find any on eBay ?
  18. #418
    Princeville, Québec
    932
    Mine(Tx/Rx) cost me around 150$ (program card and shipping included).Youcan finda8channelrx for around 8$and a stock gt3b for about 50$. If you send it to me, i could hack it for you!
    Edit:i forgot to say that i ordered mine pre-hacked, that is why it is 150$
  19. #419
    Alma, Michigan
    12,290
    FS GT3C = $50-70 and LiPo powered.
    http://www.hobbypartz.com/79p-ct3c-3...lcd-green.html
    http://www.hobbypartz.com/79p-gt3c-3ch-radio-lcd.html
    http://www.ebay.com/itm/Flysky-FS-GT...item4861bda85d
    http://www.ebay.com/itm/FlySky-FS-GT...item3388abc1bd
    8 Channel Rx = $12
    http://www.hobbypartz.com/79p-r8b-receiver.html
    The larger receiver will not fit in the stock Rx box... I bought a project box to mount mine in.
    I too, will hack it to 8 channels for you... just send it to me and cover shipping out to you.
    If you want to do it yourself:
    http://overkillrc.3dcartstores.com/
  20. #420
    Princeville, Québec
    932
    8 Channel Rx = $12
    Overkillrc is gone until march 16th... so there will be big delay for ordering.
  21. #421
    Sep 2009
    Victoria B.C Canada
    5,185
    I looked at overkill they are out of stock on the gt3c .Im on the waiting list myself.
    A bunch on eBay though.
    To bad it is not as simple as the am tx was I added a cutout switch that centered the high low switch that's what I did on mine.
    I made a winch out of a 1/5 scale servo.it would pull it up a tree if need be.lol
    Sent using lipo power
    Mountains cant stop me
    they have tried
  22. #422
    Sep 2013
    Maysville,Ky. USA
    602
    Ok so it will run a secondary esc and motor on ch3 but ch4 and 5 only allow the motor to turn in one direction or off. I will go with the Gt3c later so I can add a snow plow just wanted to see if I could get this to work for now. Still gotta open the Tx so I can peek inside.
  23. #423
    Sep 2013
    Maysville,Ky. USA
    602
    Took 2 of the battery springs from one of my cheap rc's and placed them under each side of the red toggle switch . I had to cut a small groove in the bottom of the toggle switch with a hacksaw blade to hold the springs in place. Then super glued the red part because the springs were a little stronger then i needed.
  24. #424
    Princeville, Québec
    932
    Can you post some pics? I'm curious!
  25. #425
    Sep 2013
    Maysville,Ky. USA
    602
    Quote Originally Posted by boilo56 View Post
    Sorry for the late response been working every day and trying to get ready for the family vacation.
    The spring on the right wanted to kick out at the bottom so i soldered a small piece on to stop it.
    [IMG][/IMG]
  26. #426
    1,172
  27. #427
    Sep 2013
    Maysville,Ky. USA
    602
    Awesome nice truck. Knew I couldn't be the only one to try those big tires. What's a monster truck without big tires?
  28. #428
    Mar 2014
    HB Cal.
    18
    man, Id love to have one of those trailers. Interested in selling one? Im just not handy enough to make one, but in search of one for a long time.
  29. #429
    Princeville, Québec
    932
    I was asking myself: Did you paint OVERKILL body? I shearch for that kind of color... Maybe not THAT color!
    The Newbright truck doesn't rseem to have that sort of color...?
  30. #430
    Sep 2013
    Maysville,Ky. USA
    602
    I have not painted the body it looks as though it was made this way but i have never seen another one like it and i search ebay all the time looking for a spare just in case . It does have a few spots that is slightly faded and looks like more of gold color . My son found this one at a Flea market for 6 bucks and wouldn't stop crying until i bought it good thing. As for the color i'm not real sure myself guessing metallic burnt orange or a copper something.
    There is one on ebay right now that looks some what like Overkill .
    http://www.ebay.com/itm/Ford-F150-Ra...item338bf1d5aa
    This one is just like Overkill . Wonder if they would sell just the body.
    http://www.ebay.com/itm/Redcat-MT-V3...item1c3dae4233
  31. #431
    Sep 2013
    Maysville,Ky. USA
    602
    After a few looks at the twin Summit i decided to join their forum and noticed they have a truck of the month contest which is pretty cool. I was too late to join the contest this month but will try and enter OVERKILL next month to see if he can get some votes . I did however cast my vote for the twin Overkill . Being he was the only Summit in the contest it was a no brainer. Yet somehow he is in last place out of 5 trucks so i would like to ask a few guys from here to sign up and vote for this guys Summit. GO SUMMITS !!!!!!!!!!!
    Here is where you can register.
    http://www.clodtalk.com/index.php?si...0dcd00edd1ee47
  32. #432
    Sep 2013
    Maysville,Ky. USA
    602
    Washed OVERKILL up for his introduction to the Clodtalk forums.
    [IMG][/IMG]
    [IMG][/IMG]
  33. #433
    1,172
    The guy that owns the other truck really does not know how to enjoy the sport or builds. Gave 20 reasons why his is better than yours. I thought the whole point of showing off builds is for other people to see and learn from?
  34. #434
    Sep 2013
    Maysville,Ky. USA
    602
    Not a problem mine is far from the best because it's built to my liking and what I need it for. I've seen several trucks on here much better then mine but it's my first build I'm sure they will get better with time.
  35. #435
    1,172
    that's it exactly.. everyone's build is for their driving style. their is no good or bad
  36. #436
    Sep 2013
    Maysville,Ky. USA
    602
    I must have missed the 20 reasons posting I haven't seen them or anything bad that was posted . I did make my own post on OVERKILL on their site last night but no negative comments .
  37. #437
    1,172
    Different site. Drawing a blank at the moment
  38. #438
    Toronto
    2,326
    Yeah same here, I kept searching! The guy on the link provided seemed super friendly! Interested and constructive!
  39. #439
    1,172
    Rccrawler forum. Summit area
  40. #440
    Sep 2013
    Maysville,Ky. USA
    602
    Thats why i didn't see it . Thanks Crock
    I could but i won't
