Page 1 of 2 12 LastLast
Results 1 to 40 of 74
    Sep 2013
    34
    Traxxas summit 1/16 axle carrier
    Hi everybody this is my first post so if I did anything wrong or post it it the wrong place please forgive me now on to my problem I doing a conversion on my traxxas slash 1/16 and I'm converting it to a summit I bought all the parts and everything went fine until I tried getting the axle carrier straight so that means I can't get the wheel to be straight at the same time I did replace the servo arm and axle barrier because I'm pretty sure they Are the same as the slash
    Alma, MI
    11,969
    Please try some punctuation... it makes what you type easier to read and therefore makes people more willing to help.
    The carriers are all the same across the 16ths... from your pictures (thanks for those, btw) your pillow balls are threaded out too far. Start with them almost all the way in, so that they just barely miss the arms while turning. Then, if you need more camber adjust by threading the appropriate pillow out. Then, if you need less toe in, thread both the top and bottom pillows out the same amount... be sure to repeat the same turns on the opposite side too.
    Sep 2013
    34
    Thank you do much, it worked and sorry about the punctuations
    Alma, MI
    11,969
    Awesome!
    Sep 2013
    34
    I have a another question, is the steering arm same on all 1/16 vehicles?
    Alma, MI
    11,969
    Yes it is...
    4,127
    Yep, they are all the same.
    Sl2sh Slayer Summit Sl4sh 1/18 Rally/Teton T-Maxx
    Sep 2013
    34
    I have another question, but it's not about the axle carriers, so I'm going to post it here anyways. When I plug the battery in my 'summit' 1/16, the vehicle starts to go full speed. I read a page traxxas had in that problem, but nothing worked, the only thing I could think of is replacing the esc
    Alma, MI
    11,969
    If it is the stock servo, unplug it. If everything goes back to normal, it was the culprit.
    Be sure to check your transmitter batteries too.
    Sep 2013
    34
    I just installed a new traxxas servo
    Alma, MI
    11,969
    My suggestion still stands.
    Sep 2013
    34
    How do I know if my batteries are low, does the controller flash
    Alma, MI
    11,969
    They should, but they don't always.
    Sep 2013
    34
    I changed my batteries, but no luck. Going to try to change my esc that's my last option
    Alma, MI
    11,969
    Have you unplugged your new servo to test yet? I've seen new servos "work" and cause issues too.
    What happened to the old servo?
    Sep 2013
    34
    Yes the new servo works fine, I've tested it. As for my old servo, I was changing the gears because they were stripped and I kept messing up the gears, causing me to open and close the servo multiple times and that lead to the wire that comes out of the servo to tear.
    37
    It might sound silly, but I had a similar issue with my sons, and spent 10 minutes going through all the quick fixes I knew, only to find he had cranked the throttle trim on his transmitter (to make it faster).
    Sep 2013
    34
    I have a another question, whats the best gearing for the highest torque for the 1/16 brushed summit. Also is there any other motor to replace the stock motor (not the velineon).My stock ones keep burning out. I don't want to do any modifications so please keep the motor options that way. I just want to plug the motor in the xl2.5 and go, thanks
    One more thing I forgot to add, please keep the price affordable.
    Is there anyway to achieve this look, for the 1/16 summit
    Alma, MI
    11,969
    The smallest pinion and the largest spur... plus flipping the transmission. That will give you the lowest gearing possible.
    As far as motors... I don't know of any other than stock. You may want to look through a site dedicated to crawlers as they may have some leads on brushed motors that the 2.5 can handle. I wouldn't be surprised if stock power is all it can handle.
    You may get that look with some SCT tires/rims.
    Sep 2013
    34
    So would a 55 t spur gear and 11t pinion be the best
    Alma, MI
    11,969
    Is that the lowest pinion and highest spur you could find?
    Sep 2013
    34
    Can you also tell me how to install the traxxas diff lockers. What would be the best to lock the front,back or both
    One thing I forgot to add is I'm going to be trailing and crawling.
    Yes on the chart, but the problem is that's for the velineon. I can't find a chart for the 1/16 brushed 540 that will work for the summit
    Alma, MI
    11,969
    Locking both will kill the turn radius but provide the most traction.
    Locking just the front will give you pseudo dig and effect the turning radius more than just the rear.
    Locking just the rear may cause the rear to actually stuff itself under the center line of the RC during a steep incline causing it to flip over backwards.
    Which to do is up to you.
    How?
    Remove differential, open it up, replace the 3 little gears in the cup with the Traxxas locker.
    Looking at charts is not finding pinons and spurs... you will have to dig through your favorite hobby retailer to find what is available.
    Sep 2013
    34
    So I should probably lock both
    Would this work in the summit? http://www.greathobbies.com/producti...od_id=DTXC8376
    Do the gears have to be from traxxas ?
    Alma, MI
    11,969
    No they don't need to be from Traxxas, but they need to be the right pitch and bore. Those two specifications are not in the description of the linked pinon.
    Sep 2013
    34
    Do you know a good site where I could get the gears for cheap
    Yakima, Washington
    1,380
    Try Tower Hobbies and then type in pinion gear in the search and there will be a bunch of gears to choose from, and they all will say what pitch and bore they are.
    Sep 2013
    34
    Just ordered from there, wished I lived in the u.s, these shipping prices are a little steep
    Can anyone recommend me the best crawling tires for the 1/16 summit
    Alma, MI
    11,969
    Probably stock?
    There are not too many crawling 1/16ths out there.
    Sep 2013
    34
    Ok so I just got in diff locks yesterday, and I'm really confused on how to install them. How do I install them on the front and back.
    Alma, MI
    11,969
    Post 23 says how.
    What part are you stuck on?
    Sep 2013
    34
    I got the the diffs out but don't know how to exactly install them and I don't know what gears to take out
    Now what do I do
    Alma, MI
    11,969
    Take the three screws out of the diff cup.
    Sep 2013
    34
    K I did that and installed the locker now I'm having trouble puting it back together
    Alma, MI
    11,969
    What are you having trouble with now?
    Sep 2013
    34
    Puting it back together
    Alma, MI
    11,969
    What is "it". More description is needed to know what exactly you are doing.
    157
    Take a look at this. This video helped me out.
    Sep 2013
    34
    Thanks a lot
    Can someone tell me where to buy good shocks for the 1/16 summit im having leaking problems and also if you could tell me which oil to use I wws thinking 50k for front and rear
    Sent from my SGH-I337M using Tapatalk
    SE Texas
    1,179
    HR shock bodies and use the rest of the parts off of your stock shocks.
    I use 42.5w oil in mine.
    "Dude,I almost had you"
    R.I.P Paul Walker
