    May 2013
    St. Louis MO
    23
    EZ peak Plus is it the same as a hitech x1
    I was told that they are the same charger and I want to use the dual charger tra2917 on it. its coming ups and I haven't received it yet so I thought I would ask
    Riverton Utah
    4,422
    Ya, it's basically the same charger. There is some things that are different, but not much. Some people will say different however.
    1,820
    Alot of chargers look the same, whether the firmware is the same is a different story.
    This is like comparing sports cars, Buy two identical cars, take one to get the ecu remapped, leave one standard. Now you have two cars that look the same, but now one now has better performance/efficiency than the other.
    Same goes with chargers.
    All charging accessories can be interchanged with different chargers as long as the wiring is correct for that charger and item, some need changing.
    Guide books aren't part of the packaging.
    Alma, Michigan
    12,291
    HiTec:
    Specifications:
    Battery Types: NiCAD, NiMH, Li-ion, LiPo, LiFe, Pb
    Battery Cell Count: 1-15 cell (NiCAD, NiMH), 1-6 LiPo/Li-ion/LiFe cell, Lead-acid cells (2V-20V)
    Charge Current: 0.1~6.0A (Max 50W)
    Discharging Current: 0.1~1.0A (Max 5W)
    Input: DC 11V~18V AC 100V~240V
    Dimensions: 5.31x4.41x2.40” (153x112x60.9mm)
    Net Weight: 15.27 oz (433g)
    Current Drain for Balancing LiPo: 300mA/cell
    Traxxas:
    Specifications:
    Charge Current: 0.1~6.0A (Max 80W) <<< 30 more watts
    Discharging Current: 0.1~1.5A (Max 10W) <<< Double the HiTec in wattage.
    They may look the same... they may be manufactured at the same place, but that is all that is alike between the two.
    Traxxas is the better charger.
