Results 1 to 12 of 12
    Apr 2013
    368
    Motor/esc upgrade??
    Is there a good cheaper setup that is better than stock that can be used in the merv and summit vxl.
    I want to run 2s and 3s with low temps.
    Thanks
    Alma, MI
    12,281
    I can give you a little direction...
    The stock V380 motor is fine on 2S and 3S.... the ESC is the weak point. When I was running a 60 amp ESC it was great on 2S but started overheating on 3S with the same gearing so I would think maybe an 80 amp or a 120 amp ESC would work great for 3S running.
    Apr 2013
    368
    Wow this little guy draws that many amps?!?!? Thats crazy. I used to have a couple stampede 4x4s with the tacon 3674 in it and sc8 120 amps escs... And that motor was a monster compared to this.
    What esc do you suggest then?
    Jul 2012
    Yakima, Washington
    1,420
    It depends on how much you are willing to spend?
    Apr 2013
    368
    trying to keep in on the low side
    Apr 2013
    368
    Bump just fried my esc
    Jul 2012
    A long time ago in a galaxy far far away...
    465
    You might want to look at the Castle SV3. Its waterproof as well.
    Drive. Crash. Fix. Repeat.
    Apr 2013
    368
    I dont care if its waterproof. So i take it that nobody uses a cheap esc lol
    Alma, MI
    12,281
    Where have you looked?
    Nor Cal
    408
    I run sv3 in two of my 1/16 rigs with 3s....but they are a slash and rally. Never had any overheating problems.
    Jun 2013
    Ontario, Canada
    259
    Is it possible, or is it ok to use the VXL-s ESC from the Slash4x4 Velineon system in a MERV with the 380 motor?
    Alma, MI
    12,281
    Yes... just a challenge to mount such a large ESC. I'm sure it will handle 2S fine, but I'm not sure how it will handle 3S.
