    Aug 2013
    86
    External lvd is it safe to turn of stock lvd
    I hate the stock one it cuts into lvd at 7.89 volts all the time
    So can I turn it back to nihmh and just run a external lvd on the bec side ? Or does the summit do this because it is actually dropping voltage when u flog it so its reading a lower than true reading is this correct?
    HSV CLUBSPORT BUILD#330
    Riverton Utah
    4,383
    That's what happens about 90% of the time. And yes, you can run it in nimh mode and use LVA's. Also, read the last couple of posts in this thread.
    http://traxxas.com/forums/showthread...vise-is-needed
    Aug 2013
    86
    Hmmm one bloke on there is saying that I is a minor cause of a sea battery ? Is this true I just get worried that when it is near the real lvd and I give it a boot will it drain past what it is ment to for that second ?
