Page 1 of 3 123 LastLast
Results 1 to 40 of 85
    Lexington, SC
    2,173
    Project deanodize reanodize.
    I'm going to attempt to change the color of some XO-1 aluminum parts. I'm shooting for red since there really isn't any available. Here's a pic of part of the stock motor mount after deanodizing.
    Jeremy
    Lexington, SC
    2,173
    Anodizing.
    Jeremy
    Riverton Utah
    4,361
    Wow, good luck! Could you explain how it works?
    The Netherlands
    851
    Yep please!
    I've seen quite some videos about it and read a lot about it too but all information is welcome.
    I guess you will soak the parts in a dye after anodizing? How much current are you using and what kind of electrodes?
    Lexington, SC
    2,173
    Here is a link to the process I'm using. Everything is explained here. You can also view my comments as they will tell exactly what power supply I'm using. As far as the wire leads, I'm using aluminum wire that I bought from Lowes. I bought the large cable they use to run power to your house. Just took it apart and used the single strands.
    http://www.observationsblog.com/4/po...tery-acid.html
    Oh and I used Greased Lightning to deanodize the part. Took probably 45 minutes or so. Placed the part in the liquid and let it do it's magic. Then periodically used a tooth brush to help it along. Also, moved the part around in the liquid quite often.
    Jeremy
    Jul 2012
    Yakima, Washington
    1,421
    That is pretty cool, I have always wondered how that worked.
    Lexington, SC
    2,173
    Into the red dye.
    Jeremy
    Lexington, SC
    2,173
    After dying and sealing (boiling water). Notice the 2 tone effect in the color. I haven't figured out what causes this yet, but I spray the part with an acrylic clear and the 2 tone becomes almost unnoticeable.
    Jeremy
    Jul 2012
    Yakima, Washington
    1,421
    That is a nice red. How much does it cost to do this?
    Lexington, SC
    2,173
    You need the following:
    1. Distilled water $.88 per gallon from Walmart
    2. Plastic containers about $3.00 for a pack of 4
    3. The anodizing chemical PH down that I use I think is around $6-8.00
    4. Liquid draino maybe $5.00 or so
    5. Spray bottle maybe $2.00
    6. Rit dye about $3.00
    7. Aluminum wire pretty cheap if you buy it like I do from Lowe's
    8. Power supply cost will vary
    9. Part to be anodized and some aluminum of at least 6061 quality for the cathode
    10. Lots of time!
    Jeremy
    Lexington, SC
    2,173
    After the clear.
    Jeremy
    Jul 2012
    Yakima, Washington
    1,421
    Are you planning to do all the parts on your car like that, because if you did it would look killer.
    Dec 2006
    4,386
    Awesome! I like it!
    Lexington, SC
    2,173
    Quote Originally Posted by revoman78 View Post
    That's the plan, although I think the wheel hexes are what's gonna give me fits. They are gonna be tough because there isn't a sopt for a really good connection. Most of the aluminum parts have some type of threaded hole or another that I can screw my aluminum wire into. That makes for a really good connection. The hexes have a threaded hole but the nuts do not. Also, the part does not anodize at the connection, so I will have bare spots on the nuts. Once they are installed, you won't see them but I'll know they're there. Just have to see what happens. I'm really excited to do the shock towers. They'll look really nice in red.
    Quote Originally Posted by danielhr77 View Post
    Awesome! I like it!
    Thanks!
    Jeremy
    Dec 2006
    4,386
    You know, I anodized most of the parts from my trucks, the vintage ones to their stock color; the new ones, mainly to black or silver, there's a shop here that makes that for me, but your read looks very very good!
    Lexington, SC
    2,173
    Thanks man! It's not perfect, but is super nice for doing this at home. Might try the shock towers next.
    Jeremy
    7,171
    Ooooh I like! I think i'm going to have to give this a shot in the future. I'll be playing the video instructions here shortly.
    Awesomeness!!
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Lexington, SC
    2,173
    Just keep in mind that there is a learning curve with this. It took me several tries before I finally anodized successfully. Distilled water, aluminum quality and power supply are key. Be patient and have fun with it. It is really quite cool once you get the process down and opens the door to some really cool upgrades to your RC.
    Jeremy
    Michigan
    5,220
    If your not overly concerned about the threads, or at least where it wont show, maybe an aluminum pipe fitting would do the job.
    It may take a couple fittings but should work.
    Something like this for the nut, then reverse it for the hub.
    Not positive but it may make an sufficient connection, and give an area to connect your aluminum wire.
    Just a thought.
    http://www.alibaba.com/product-gs/59..._fittings.html
    Lexington, SC
    2,173
    I have a few ideas with the aluminum wire. I should be able to get it. There will be some bare aluminum spots on the threads, but those won't be seen once installed so shouldn't be a big deal.
    Jeremy
    Lexington, SC
    2,173
    I think I might go ahead and deanodize the shock towers on Wednesday. If I have time, I may anodize them as well. I'll post pics.
    Jeremy
    Jeremy
    Jul 2013
    Saskatoon, SK. Canada
    2,160
    Nice project!
    Lexington, SC
    2,173
    Thanks!
    Jeremy
    Jeremy
    Lexington, SC
    2,173
    Working on the front shock tower today. Ready for anodizing.
    Jeremy
    Lexington, SC
    2,173
    Finished the shock tower. The motor mount is darker. I think I'll need to use a bigger piece of aluminum for the cathode. The shock tower anodized well, but I think it was pushing the limit size wise.
    Jeremy
    Jul 2013
    2,160
    Oh man!! I so want red anodized parts too
    Lexington, SC
    2,173
    Quote Originally Posted by ViperZ View Post
    Sent you a pm.
    Jeremy
    Jeremy
    Jul 2013
    2,160
    Okay, going to check....
    Dec 2006
    4,386
    That looks awesome! Can you take a short vid next time you anodize one?
    Lexington, SC
    2,173
    Not sure when I'll be able to but I'll see what I can do.
    Jeremy
    Jeremy
    Lexington, SC
    2,173
    Something else to mention is I was finally able to anodize a part in black. That is an accomplishment because black is the hardest to do. It is made up of all colors and being able to do it is a testament to having good pore size. So, this process is pretty solid.
    Jeremy
    Jeremy
    Dec 2006
    4,386
    Awesome! FOr now, I'll stay with the ano shop, I don't think I have enough patience to do it... Keep the good work!
  33. #33
    Lexington, SC
    2,173
    Working on the hex nuts tonight. After deanodizing:
    Into the anodizing tank:
    Jeremy
  34. #34
    Lexington, SC
    2,173
    Finished up the hex nuts. Before anodizing, I did a quick polish on them to give them a little shine.
    They look great with my black hex adapters. Sorry for the bad lighting.
    Jeremy
  35. #35
    woodstock .on.canada
    2,197
    wow im blown away.....
    the biggest thing that got me is that you use basic rit dye. awsome!
    and how is the finish/durability....after you anodized the part did the anodizeing come off eazly.
    summit /mustang /stampede-2s spc lipo
  36. #36
    Aug 2012
    Warner Robins, Georgia
    1,427
    Wow, that is absolutely amazing!! You should do a video on your process to explain how it works and what you use. Way to step up the customizing game of RC lol
    Sent from my SCH-I535 using Tapatalk 2
  37. #37
    2,197
    never thought of it but i can finaly have red 17mm hex hub's for the pede
  38. #38
    Lexington, SC
    2,173
    Quote Originally Posted by reod12x2 View Post
    After anodizing, I let the parts air dry. Then I wipe them off with a terry cloth. You get an initial haze of color that comes off but it's not much. The pics were taken after I wiped them off. I would say it's just a color residue that's left on the part after the sealing process.
    Quote Originally Posted by mrtwohands View Post
    There is a link earlier in this thread to the process I use. I've tweaked it here and there which is something you just have to do to figure out what works best for you and the conditions you have.
    Yep. It's time consuming but I enjoy seeing the results.
    Jeremy
    Jeremy
  39. #39
    Aug 2012
    1,427
    Hmm how did I miss that lol. Again awesome job on those parts. Can't wait to see everything sompleted.
  40. #40
    Lexington, SC
    2,173
    Thanks. It will take somevtime to get everything done. I'll keep yall updated.
    Jeremy
    Jeremy
