Results 1 to 10 of 10
    Sep 2013
    22
    2650kv gearing help!!!
    I upgraded my current e revo to brushless from being brushed. When I purchased the mamba monster 2 combo for my e revo, I made a rookie mistake of thinking higher kv means better. I purchased the 2650 kv instead of the 2200kv. I do not plan on running 6s anytime soon which would be hard to do with a 2650kv motor. I do not have the funds yet to purchase ANOTHER motor so I want to make due with what I have for the time being. What would be an ideal gearing for the 2650 motor? I run mostly on grass and off road surfaces more than I do on the road. I want a gearing that will keep the temperatures somwhat low without sacrificing to much power and speed. I am getting the fan for the motor today so that should help with the temperatures for a bit.
    kansas
    7,843
    I would try 18/54 to start......
    On 2/2S lipo with the 2650kv motor:
    18/68 = 35mph
    18/62 = 38mph
    18/58 = 41mph
    18/54 = 44mph
    20/54 = 49mph
    A temp gun is kind of a must have.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    Diff ratio
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    change the cell count, spur & pinion count, & tire size.
    BrianG speed chart:
    http://www.scriptasylum.com/rc_speed/top_speed.html
    Copy / paste: Import this:
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 54
    Pinion Tooth Count: 21
    Total Voltage: 22.20
    Motor KV: 2200
    Tire Diameter (inches): 5.9
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0.006
    Spur/Pinion Ratio: 3 : 1
    Total Ratio: 15.65385 : 1
    Tire Circumference (inches): 18.54 inches (470.8 m
    Sep 2013
    22
    Thank you!!! I am looking to sell my 2650kv in the mean time. Want to get the 2200kv and be all set!!! Quick question...what would the speeds be with the 2200kv with common gearings? Would the 2200kv be good for all around bashing?
    18/68 = 35mph
    18/62 = 38mph
    18/58 = 41mph
    18/54 = 44mph
    20/54 = 49mph
    Diff ratio
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    BrianG speed chart:
    Other Ratio: 1
    Motor KV: 2200
    kansas
    7,843
    21/54 high 40's to low 50's.........mph
    Yes......
    Sep 2007
    Virginia
    996
    I ran 18/58 on 4s very comfortably without breaking a sweat. Could possibly have gone 20/58 but did not really need it. Plenty of torque and enough speed for bashing. Temps were around the 140's and esc fan on occasionally. I also would let esc fan continue to run at the end of the session if it was running at that time. Purely guess speeds of about 45 or so.
    Never do anything half fast. Hey Ya'll, watch this
    Sep 2013
    22
    You ran your revo with the 2650kv mamba monster motor?
    Quote Originally Posted by glbobo View Post
    Sep 2007
    Virginia
    996
    Yes, and in several configurations:http://traxxas.com/forums/showthread...e-beginning...
    Sep 2013
    22
    You like it? What made you go with that and not the 2200?
    Sep 2007
    Virginia
    996
    Yes I like it. Started as a motor for a Slash 4x that could also push the E-Revo. Worked out for less weight as well. The 2650 is 2 oz lighter. I also knew I would only be running 4s.
    Sep 2013
    22
    That is true...I guess I never thought of it that way. I agree with you on the battery capacity. I do not plan on running 6s anytime soon. Do not see the point of having to buy parts everyday . I am just unsure if this motor was the right choice because most people use the 2200 kv and not the 2650 but I look at why and they use 6s.
