Results 1 to 10 of 10
    Alma, MI
    12,280
    Speed Guide: Axle replacement
    Remove fasteners tagged in red.
    Slide what is tagged in green.
    Then slide back.
    This entire process takes me less than 5 minutes.
    I performed this on the rear, but the front is very similar... and actually easier because you can turn the knuckle.
    Riverton Utah
    4,351
    Nice write up!
    Alma, MI
    12,280
    I figured it was needed since there was a thread recently that the poster had removed the entire knuckle to get the axle out.
    lol
    Riverton Utah
    4,351
    ^ Ha ha ya I saw that! Guess this might help.
    Jan 2002
    305
    great write ups for the noobs. wonder if you could lump them together some how and put them in a sticky for the beginners.
    Sacramento, CA
    588
    Yeah I agree. Thanks for the write up. These speed guides are great. Should be in a sticky for sure
    Used the one to get the diff out and worked like a charm.
    Sent from my iPhone using Tapatalk - now Free
    2,048
    Quote Originally Posted by rizz0d View Post
    That would be a good idea. Hmmmmmmmmm
    MAN, Use Common Sense
    Funky Gecko, SumVee HDE
    Jun 2010
    New Hampshire
    341
    I have been having an issue with getting the axles bac into place with the outer wheel bearing not fitting onto the stub axle correctly and I have to hit and force the bearing on...any thoughts on why this is happening and or solutions?
    "Duct tape and superglue are my spareparts"
    Sep 2009
    Victoria B.C Canada
    5,111
    The hole where the pin holds the hub in place gets burrs from the slamming force it takes.
    I have a small fine flat file for dressing the stub end when that is needed.just a few strokes will usually be all that's needed
    Sent using lipo power
    Mountains cant stop me
    they have tried
    Alma, MI
    12,280
    Yup... Jamann is correct. Just slight burrs that keep the bearing from wanting to slip on.
