Results 1 to 14 of 14
    Aug 2012
    Alberta Canada
    895
    E Revo Mod 1 gearing.
    Hey,
    I have a few Mod 1 geared RC's and I was planning on using mod1 in my Erevo as now all my RC's will have a full selection of Mod1 gears.
    I can use the 40T from the Nitro Revo and 14/40 would be about the same ratio as i have now, but will this small of gears fit? if there is a mod1 gear in the 50t range that would be perfect.
    Nov 2008
    Troy Michigan
    1,456
    Whats the benefit of mod1 gears? Is it only to reduce stripped gears?
    E-Revo MMM-2200 6s
    Aug 2012
    Alberta Canada
    895
    Pretty much, they work better in dirty environments, I mostly want to add mod 1 becuase I have a lot of mod 1 pinions so its cheaper to have a full set of pinions.
    May 2009
    Edmonton, Alberta
    3,604
    If you run without the ESC hold down 14/40 might fit.
    I run 20/38 right now and have to shave the side of the ESC hold down to avoid rubbing.
    Aug 2012
    Alberta Canada
    895
    Its a close fit, I may just try it. Ill keep looking for a bigger spur,
    Posted by my Galaxy tab 3 8"
    May 2009
    Edmonton, Alberta
    3,604
    I dont think anyone makes a spur larger than 40t that fits the Revo mounts.
    Not sure if anyone makes a slipper for the Revo that can accept a larger spur either.
    Aug 2012
    Alberta Canada
    895
    I wonder if a mgt spur would fit
    http://kimbroughracingproducts.com/s...oduct_id=29849
    Long Beach, California
    6,578
    I don't think a Mod1 52t have room but I could be wrong
    you might be able to find a 42t hardened steel aftermarket.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
    Aug 2012
    Alberta Canada
    895
    A 42 is easy, I wanted to get something inthe 50s I know 20/54 works good
    Middle of the Pacific Ocean
    171
    MGT spurs are what other mod 1 traxxas conversions are using. You may have to mod things on the erevo to allow it to clear.
    Aug 2012
    Alberta Canada
    895
    Its only 4 bucks. Next time I make an order ill get one and see how it goes
    Posted by my Galaxy Note 2
    Aug 2012
    Alberta Canada
    895
    Just an up date the 40t is way too small. Needs at least a 50t to fit decent
    Sep 2013
    21
    I have ran all types of gearing all the way to 30p 34spur try spinning the motor and lining up with the othe holes. It will change the position of the output shaft and makes it easier to fit without shaving the esc mount.
    Sep 2013
    4
    Robinson Racing 7350
    You can use the Robinson Racing HPI 7350 slipper/spur unit on the erevo transmission. This will give you a hardened steel 50 tooth mod1 spur that fits perfectly on the erevo.
