Results 1 to 24 of 24
    Sep 2013
    Draper utah
    53
    Questions about 1/16 e revo
    I got my brushed merv back in April, and have a few questions about it. I want to get the proline trencher tires with the traxxas dish rims, and I want to know how to gear it properly. Also how am I supposed to know when my diff is perfectly shimmed? I have the associated shims. I might also upgrade to brushless and want to know what motor is cheapest and best, I will get the sidewinder 1/10 as the esc. Thanks!
    A long time ago in a galaxy far far away...
    465
    In terms of the motor, you should be fine with the velineon 380. The sidewinder will be more than enough power for you on lipos. the gearing should be fine with that motor and those tires. as for the shimming:
    http://traxxas.com/forums/showthread...jimmie+neutron
    Drive. Crash. Fix. Repeat.
    Sep 2013
    Draper utah
    53
    Thanks for the info funny! But I have my bulkhead taken apart and have no diff fluid. Could I go without the fluid? Also my shocks are leaking and I am going to get the gpm ones. Are the springs that come with it good for 1-3 foot jumps?
    Alma, MI
    12,279
    Fluid is essential if you want traction.
    The brushed version is fine for what you want in upgrades... as far as gearing, only a temperature gun can tell you that.
    Sep 2013
    Draper utah
    53
    Is fluid the stuff inside or outside, because I have the inside stuff but not the outside stuff…
    Alma, MI
    12,279
    Inside the differential.
    Any grease will work for the inside of the bulkhead, but I chose to use none due to the simple fact that grease + dirt = sandpaper.
    Usually, the differential leaked enough to keep the ring and pinion lubed yet not enough to attract enough dirt to hurt anything.
    Sep 2013
    Draper utah
    53
    Great info. Now that I know my brother has grease for his airsoft gun that I could use for my bulkhead if I choose to use it, I'm sure he'll let me.
    Gold Coast, Australia
    392
    At least half fill the diff (I do about 3/4)
    The bulkhead I dust inside with Graphite powder, dry lubes and repels dirt.
    Sep 2013
    Draper utah
    53
    I have some graphite powder i could use, and about the shocks, should I get the aluminum shock towers or are those a waste of money?
    So Cal
    513
    I LOVE this stuff:
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    I spray some in a cup and apply it with a small brush. when it dries you have a 100% Teflon coating - SWEET!
    PERFECT for R&P and transmission gears IMO
    There are lots of ways to do that. Most are wrong.
    Alma, MI
    12,279
    The Revo doesn't have shock towers... there are shock mounts, though.
    Aluminum shock mounts wouldn't be a whole lot of improvement I imagine. They are really small to begin with so I doubt there is much flex there.
    If you are talking about body mounts, no... aluminum there is a bad idea is that area needs to flex when you flip it over.
    Sep 2013
    Draper utah
    53
    Ok, I am having problems with the rear bulkhead. I've been trying to shim it, but with 0,1,2,3, or 4 shims it's always hard to spin the pinion! (Havent done the front yet.) Do I need to get another bulkhead?
    sacramento, ca
    742
    You might not need shims if it's hard to spin with them on.
    addicted much....
    So Cal
    513
    should NOT be hard at all. If there is one spot that is SLIGHTLY tight that's probably OK.
    If the diff does not spin freely with no shims something is wrong! maybe a bad bearing or?
    Check if it spins free without the pinion installed. You have to determine where the friction is coming from.
    Check bearings carefully
    And, the finisher is absolutely right, there is no mandate to have shims - some don't need any!
    Alma, MI
    12,279
    The cup can be overtightened... depending on the weight of the oil, you may not be able to spin it by hand, but you should be able to spin it with a little more leverage.
    Sep 2013
    Draper utah
    53
    Alright, I probably forgot to put a piece behind he bulkhead once and screwed in the screws and then realized I had to put that piece on. The screw pushed the plastic in and was rubbing against the teeth, but its all good now. My bearings are fine too.
    Sep 2013
    Draper utah
    53
    Can anyone tell me what gearing they use for the dirt hawgs?(not on Titus beadlocks)
    Alma, MI
    12,279
    I used stock "speed" gearing on 2S.
    But, the only way to tell what works for you is to use a thermometer.
    Sep 2013
    Draper utah
    53
    I can't find the gpm shocks anywhere but ebay, they seem to be discontinued. I can't find any good shocks exempt the gtr and those are like $65! I am on a budget and need to find some good shocks! Also I want a lipo! I've heard the spc 2500 is good, but what charger do I need to buy? Is there anything special I have to do each charge?
    Jun 2013
    Afghanistan
    55
    Quote Originally Posted by lando calrician View Post
    The Toyz still have GPM shocks in stock. They only have red, green and orange in stock though. Here is a link to the red:
    http://www.thetoyz.com/Traxxas/Mini-...sis/GPM/12501/
    If you are on a budget I think you would be better off getting the Hot Racing aliminum shock bodies and using everything else from your stock shocks. Here is a link to the Hot Racing aluminum shock bodies:
    http://www.thetoyz.com/Traxxas/Mini-...-Racing/12443/
    Alma, MI
    12,279
    I was going to suggest the same thing... HR shock bodies:
    http://www.liquidrc.com/index.php?ma...ducts_id=61833
    As far as which charger...
    On a budget: Simple balance charger
    -- Will take ~132 minutes from LVC to 4.2v/cell.
    Spending a little more: EZPeak+
    -- Will take ~42 minutes from LVC to 4.2v/cell.
    Possibly the only charge set-up you will ever need: iCharger + power supply.
    I was able to purchase mine for less than $200... and can safely charge up to 6 of the 2500mAh packs in ~42 minutes.
    Sep 2013
    Draper utah
    53
    Does the balance charger auto turn off?
    Alma, MI
    12,279
    I believe so... might be good to find and read the manual on it though.
    Slovenia
    281
    .....The status LEDs confirm how many cells are charging, and let you know when charging is complete.
    I believe that every Li-PO charger has a cut-off. It is much to dangerous not to have
