Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 81
  1. #41
    Covina, So Cal
    638
    Quote Originally Posted by E-Maxxdude View Post
    Never mind. If you crank the rod ends all the way down, you can use them as camber links, but you don't get much adjustment. You might get 2-3 degrees negative camber at the most, but you could get all the positive camber in the world...
    It's funny you posted that, I was just about to post that they are too long, but can be turned in all the way. I don't think I'll be needing any negative camber anyway! I figured that they put the solid ones on for a reason, so I just set them at the same length.
    I didn't bring any hardware with me, so I'll be installing them tomorrow.
    AB
  2. #42
    Traxxas Employee
    Aug 2013
    Dallas
    148
    Actually, we still have the standard camber adjustment using the various mounting holes, but I don't think any of them give you more negative camber. Maybe one does. Almost all of them give you positive camber. If you cut maybe 1mm off both ends of the rod, you could have a lot more adjustment range. The rears are going to be a tight fit though. I think the rear plastic camber links are the same length as the front pushrods on a mini Summit and you can get those in aluminum, but they aren't adjustable and only come in red.
  3. #43
    Covina, So Cal
    638
    OK, Thanks for the info!
    AB
  4. #44
    Covina, So Cal
    638
    I got the rest of the parts in yesterday, and got them installed today...
    [IMG][/IMG]
    I didn't realize that the front & rear camber links were different sizes, the fronts I was able to tighten down all the way to match the plastic links length. The rears was a different story. I had to cut about 3.5mm off each end as they are 7mm shorter than the fronts.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Here's the heat sink motor plate...
    [IMG][/IMG]
    [IMG][/IMG]
    I also dropped in a 12T pinion, that caused me to have to trim a little more off the driveshaft tunnel...
    [IMG][/IMG]
    [IMG][/IMG]
    AB
  5. #45
    Covina, So Cal
    638
    Then, it was time to work on the roof lights. I originally wanted to go with the 6-can rack, but it's longer than the roof is wide. I tried to figure out how E-Maxxdude mounted his, but I wanted to use the Pro Line parts. I ended up using the 4-can rack, which worked out nicely. Pro Line puts out a nice setup!
    [IMG][/IMG]
    I had to trim a notch in the rear caps for the wires, then screw them on.
    [IMG][/IMG]
    Then after mounting them in the rack, a little wire tidying...
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    The links...
    [IMG][/IMG]
    The finishing touches will be to paint the Bead-Loc rings orange to match the body, and the 300K diff oil(paste!).
    AB
  6. #46
    Covina, So Cal
    638
    Here it is with the lights on...can't wait 'till dark!!!
    AB
    [IMG][/IMG]
  7. #47
    Temecula,CA
    1,743
    Love it!
    Slash 4x4 LCG, Rusty VXL(not runnin), and my bike.
  8. #48
    Covina, So Cal
    638
    Quote Originally Posted by sean1214 View Post
    Love it!
    Thanks!
    AB
  9. #49
    Traxxas Employee
    Aug 2013
    Dallas
    148
    Put a thin bead of silicone around the front lenses on your PL lights. I flipped and lost two of them in the park yesterday. They don't stay in well if you have a rollover.
  10. #50
    Covina, So Cal
    638
    Thanks for the tip. I noticed that they were only snapped in. Also, I have some spare RPM lenses from their 4 Can setup that fit the TRAXXAS stock cans. I'll probably use that method to secure them too. Whatever you do, DON'T USE CA!!! It will cloud the lenses!
    AB
  11. #51
    39
    How about a running video of this badboy?
  12. #52
    Covina, So Cal
    638
    Quote Originally Posted by Jigs View Post
    I'm going up camping in a couple of weeks, hopefully I can get someone to hike a trail with me to get some footage.
    I just ordered some 300K & 500K diff oil to see how that works out, also I may drop a 2400Kv motor in to slow it down a little more.
    AB
  13. #53
    Covina, So Cal
    638
    Hello guys, today I got some time to dig out a little trench in my boy's track. I got him(he's 5) to take a short vid of the Telluride for me. I edited it to slo-mo so I could see the suspension action. Here it is...
    http://s1337.photobucket.com/user/ab...c32b9.mp4.html
    That's running with the soft compound Pro Line Badlands. I'm going to try the soft compound Trenchers next.
    AB
  14. #54
    Temecula,CA
    1,743
    Thanks for the vid!!
  15. #55
    13,082
    I have never seen this thread before today? Why has this not ever been on my page?
    Nice build. Subd'
  16. #56
    Covina, So Cal
    638
    Nice build. Subd'
    I started this thread the day I got it delivered! It's about a month old now, having a blast!
    AB
  17. #57
    Covina, So Cal
    638
    Hey guys, I have the full video here..http://youtu.be/M3U4FEcPARc
    This was filmed by my 5 year old, soon to be 6. Our dog even got into the action!
    AB
  18. #58
    Covina, So Cal
    638
    Here's a shot with the Trencher X SC soft compound. I heard Jang make a reference to "scalloping" the foam for more tire compression & grip. Anyone know how to do that?
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    OK, a few shots!
    AB
  19. #59
    Temecula,CA
    1,743
    Nice pics!! I have never heard of "scalloping," how does it do on the slower stuff with the heavier wt diff fluid?
  20. #60
    Omaha, NE
    72
    I would believe that 'scalloping' would mean slicing the foam to soften them up. Not so much as to cut the foam all the way through but maybe half way down.
  21. #61
    13,082
    At first I did not like the look of the tellu, but its growing on me 8)
  22. #62
    294
    Just do some triangle cuts in the foam so when yer done it looks like a big gear. It helps the tire compress a little better to have more contact with whatever rocks yer climbing over.
  23. #63
    Covina, So Cal
    638
    Quote Originally Posted by VMX12R View Post
    Quote Originally Posted by dugsguns View Post
    Thanks guys! I did some research on the subject and that's exactly what I found. With the soft compound Trencher x SC's, this foam mod should cause the tries to work well.
    AB
  24. #64
    Covina, So Cal
    638
    Yeah, I think it's a cool little truck!
    AB
  25. #65
    Covina, So Cal
    638
    Ok, latest update, I got the Stampede arm & shock protectors. I only put the fronts on for now. I also did that tire foam mod so the tires can compress easier. What a difference! I changed the rear diff fluid to 300K. I'll have to give it a go tomorrow & see how she runs!
    Cheers! AB
    [IMG][/IMG]
    [IMG][/IMG]
    Looks kinda weird, but the SC foam is very shallow, so I couldn't do deep "V" cuts. But it works!
  26. #66
    Covina, So Cal
    638
    Hey guys, I've been running my telly recently, both with 2S & 3S LiPo's, only to have my Castle MMP go into thermal mode regularly. This happens when going slow through rocky trails, or running fast doing jumps and such. I'm running 12/54 gearing with the Pro Line Trencher X SC's. I'm thinking about running a Muchmore micro fan on top of the ESC, as I really don't want to change the gearing. The 2800Kv 550 can motor doesn't even get warm. Any thoughts??
    Also, I got my Pit Bull R/C crawling tires in, and I ordered some Pro Line "memory foam" for those tires, I'm looking forward to trying them out! Also, I really enjoy being able to drive in the dark with the lighting kit, makes for some great night time fun!
    AB
  27. #67
    Feb 2014
    Sweden
    86
    Wauw man,looks very nice, lots of changes
  28. #68
    125
    looks awesome love the build
    but man you have to have over a grand into this thing already
  29. #69
    Covina, So Cal
    638
    Quote Originally Posted by arp15001 View Post
    Not even close!!!
    AB
  30. #70
    Wales in the UK
    5,288
    Well dude I have just finished reading this and all I can say is what a sick and well though out buildkeep up the awesome work.........peace
  31. #71
    Covina, So Cal
    638
    Thanks! I can't wait to try the Pit Bulls out!
    AB
  32. #72
    Covina, So Cal
    638
    I finally got some pics of the Pit Bulls, still waiting on the foams though. I'm going to mount them on the Pro Line 3-pc Bead-loc's.
    AB
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  33. #73
    Feb 2014
    Sweden
    86
    They look great
  34. #74
    New Hampshire
    638
    Wow I'm jealous
    Awesome build keep up the good work!
    And we thought toy grade RC's where cool...
  35. #75
    Temecula,CA
    1,743
    Are those 2.2"s?
  36. #76
    Covina, So Cal
    638
    Are those 2.2"s?
    They are standard S/C, 3.0/2.2.
    AB
  37. #77
    28
    Are they a soft tire or medium compound.
  38. #78
    Covina, So Cal
    638
    Quote Originally Posted by Mlevek13b View Post
    Super soft! They are designed to flex quite a bit for more grip over rough obstacles.
    AB
  39. #79
    Sep 2013
    24
    I am looking for 2.2 tires from Proline for trails/bashing. Which did you like best the Badlands or Trenchers?
  40. #80
    Nov 2013
    Missouri
    218
    Man that's coming along good making me want to get one now
    Slash 4x4 & E-revo brushless
